SoS Kit and AEMV2 Tough to Start
Old Sep 20, 2020 | 10:04 AM
Z32MadMan's Avatar
Default SoS Kit and AEMV2 Tough to Start
Any suggestions for adjustments to improve starting on a 2005, SoS kit using AEMV2?
Car cranks for 6-7 seconds before it comes to life. Happens first thing in the morning and when the motor has been off for 15-20 minutes.
Car is based in Florida.
I have read numerous posts from 7+ years ago working the same problem, wanted to see if there was something more definite at this point.
Thanks!
Old Sep 20, 2020 | 10:45 AM
ryiin2's Avatar
In general AEM V1/V2 take longer to crank. From what I hear it's a quirk of that ECU.
Old Sep 21, 2020 | 11:58 AM
scottdh20's Avatar
mine always fires right up. pm ap1chief he can remote in and probably clean it up. i do cycle my key twice though when it dips into the 50s and below being on e85 but 60+ degrees it always fires immediately. e85 on a aem series1
Old Sep 22, 2020 | 11:47 AM
tylek17's Avatar
Mine can be the same way if the battery is weak from sitting or being cold. I like to keep it on a battery minder when possible. Helps a lot.
Old Sep 22, 2020 | 06:27 PM
CHOWBOX's Avatar
No or bad check valve in the pump or a fuel pressure regulator that has a bad diaphragm. Fuel is falling back to the tank. When stating warm it’s already at the rail and pops off. When sitting it rolls back to the tank and takes a few seconds of cranking to get up to the engine. Don’t think this is a engine management issue at all.
Old Sep 24, 2020 | 04:40 AM
timg's Avatar
When I had a V1, if I turned the key, waited a few seconds, and then started, it fired right up. If I immediately tried to start, it took 5-6 cranks.
Old Sep 24, 2020 | 07:52 AM
johnckeen's Avatar
I always wait for the fuel pump to finish priming before I start my car, it still takes a couple seconds to fire due to crank sensor I believe so just live with it, not a real issue tbh.
Kiwiflavored
Sep 1, 2016 09:17 AM
Srfns
Cars for Sale
Jul 8, 2016 02:28 PM
daveishi
R&C Parts For Sale
May 8, 2016 02:24 AM
