SOS Novi 1200 orientation wrong?
Old Jun 24, 2016 | 06:24 PM
amdaman's Avatar
Default SOS Novi 1200 orientation wrong?
Hi,
I'm trying to get things ready for my Novi 1200 upgrade. So I got the CT bracket conversion and a new blower, I've just done the dummy bracket fitting and it looks totally wrong as the outlet is pointing upwards! Am I doing something wrong here?
Old Jun 24, 2016 | 07:31 PM
soulicious's Avatar
It looks like they you the wrong volute. You might have to wait a few weeks to get the correct one...j/k. You need to loosen the allen heads bolts, align it to the aftercooler inlet, and then tighten up the allen head bolts.
Old Jun 25, 2016 | 12:02 AM
amdaman's Avatar
Awesome man, thanks!
Old Jun 25, 2016 | 05:08 AM
rmerchant3's Avatar
I read your first sentence and almost immediately responded with a WHAT?!
It's super easy to clock though.
Old Jun 25, 2016 | 04:42 PM
Chitoki's Avatar
Its correct, all you have to do is loosen the bolts and clock it.
Old Jun 25, 2016 | 05:50 PM
Kenny_Stang's Avatar
I'm doing the same thing this weekend! I've already gotten the 1000 and aftercooler off and parts swapped over, tomorrow will be mounting and putting it all back together.
Old Jun 26, 2016 | 02:21 AM
amdaman's Avatar
Cheers, I've loosened the bolts and will get the orientation right once I've mounted it onto the engine then tighten the bolts with it all in place.
Good luck Kenny. I've noticed a few things different like the oil drain mounting and fittings look to be push hose instead of a threaded connector.
There's also a few drain hole plugs around the supercharger, I'm waiting for some sealant to make sure they don't leak..
Old Jun 27, 2016 | 04:54 AM
I removed the push hose connector and used the AN fitting from the Novi 1000, was a real PITA to get in there as as socket won't fit, and the space is really tight for a wrench.
Other than that everything else went very smoothly, mine has the black coating and I think it looks great (though it can get scratched fairly easily).
Old Jun 27, 2016 | 07:42 AM
amdaman's Avatar
Looks great Kenny.. Any reason you didn't keep the 1200s push connector for the oil drain though? The Novi 1000 drain is a nightmare!
_valtsu_
Mar 10, 2025 02:35 AM
kop-O-nen
Mar 21, 2013 05:08 AM
s2konroids
Mar 16, 2012 02:26 PM
Benihana
South Florida
May 11, 2010 08:46 PM
manolo.cabasal
Dec 10, 2009 01:50 PM
