SOS S/C High Boost
So in my quest to make more power with my setup, I believe I may have overlooked something. I am going with a 6.6" crank pulley and a 3.4" s/c pulley on a novi 1200. That equates to almost the same as a stock sos crank pulley and a 3.0" s/c pulley. That setup seems to put members on here in the 20psi range. Where I think I may have overlooked is my gas tune. I know that the E85 and can handle those pressures at 8000rpm, but will 93 octane be able to? I haven't come across anything where the 1200 was pushed this far on pump gas. I thought about asking my tuner to limit the rpm to 7000 on the 93 tune to protect against any failures. Any thoughts or suggestions?
I spoke to my tuner about this also, he basically said that you can't just limit your petrol tune to 7000rpm or whatever on 93 because the flex fuel map is obviously interpolating between two tunes, and to do this successfully your tuner will need to rev both tunes (E85 & 93) out to the max rpm you wish to run on E85 (8000rpm)
Whats possible aside, your at the mercy of your tuners skill set and a big part of that is not only the familiarity with tuning sc s2000 specifically, but reading knock, if there is any doubt on his part to do these two things, id advise you to pulley back up to 4" to hover around 15psi peak. Can you squeeze out more reliably? Questionable, your pushing it, so refer back to first part of my reply. Also keep in mind that your currently over spinning the blower beyond its safe limits. Its rated for 52,000 rpm. That puts you at the stock 5.45" crank with 3.2" at roughly 8350rpm. People have successfully over spun this blower and yielded good power results, but for how long is unknown. Your producing a lot of added heat the bearings weren't designed to handle.
