SOS Stage 1 dynod
Old Jun 4, 2010 | 05:23 AM
camuman's Avatar
dang 8.5, yeah check with sos for sure, but if thats the case, leak or loose belt.
msutang dynos rely on the weight of the car being input correctly, what weight did they put in for your car? even then, they ussually read lower. you would have to fudge the weight to make it read higher.
Old Jun 4, 2010 | 05:49 AM
rosscoe21's Avatar
Originally Posted by RAIN H8R,Jun 4 2010, 02:49 AM
call up Chris @ SOS. Perhaps he can give you some insight. Ask what the PSI should be with your kit. It beats going off of what people "think" you should be running. When in doubt, goto the source for information.
I have the exact same kit, he should be hitting 8.5psi at redline.
Old Jun 4, 2010 | 08:08 AM
MasterForce's Avatar
ok i will give SOS a call and see whats up. i dont know what weight they put it but im sure that wouldnt affect boost anyway.
Old Jun 8, 2010 | 06:49 AM
tre3478's Avatar
I just installed this kit, aftercooled kit SOS -
Put on a dyno that is a dyno where you "leave your wheels on" ( i dont know tech stuff)
I put down 301.7 WHP - at 5.9 pounds of boost
I have ap1 stage one kit
I dont know if this will help, but i figured i would let you know
thanks!
Old Jun 8, 2010 | 06:50 AM
tre3478's Avatar
oh didn't see you are AP2... i might not be much help i have AP1
Old Jun 8, 2010 | 07:04 AM
Darkside_Z's Avatar
Sounds like a boost leak to me. I would definitely check into that first.
Old Jun 8, 2010 | 06:29 PM
ill troubleshoot it this weekend. anyone think its the belt not tight enough? ill zip tie the lines that go to the BPV
michaelnyden
Jul 6, 2015 12:47 PM
Kitesurfer s2000
Jan 25, 2011 01:08 PM
lookinco
Jun 17, 2009 05:08 AM
