SOS Supercharger Kit FAQ Sticky
#1471
After reading all 147 pages of this thread, I've decided to pull the trigger on a Stage 2 kit for my 2006. I have one last issue that I can't figure out though. For engine management, SOS supplies the KTuner EMS instead of Hondata FlashPro. From what I can tell, tuners seem to prefer the FlashPro. I've talked to a local tuner who can do KTuner, but even he seemed more comfortable with FlashPro. So I'm wondering if anyone's got experience with KTuner? Should I stick with whats supplied or ask SOS to send me a FlashPro instead???
#1472
Why not just do the SOS tuner kit and supply your own flashpro? You can run any size pulley you want as well, and not be fixed to 9psi. The blower and motor will handle much more. Might as well do the 1200 optional upgrade as well. You will get more for your money, rather then being locked into a stage 2 supplied package.
#1473
As best I can tell, buying the tuner kit + EMS + fuel system a la carte seems to cost more than just buying the package with KTuner. Other maybe relevant details that I left out are that I plan on doing the 1200 upgrade. Haven't decided on pulley size yet. Basically I want the smaller pulley size only if I dont need to get into the other upgrades like MAP sensors, fueling, and all the other stuff that isn't supplied with the stage 2 kit.
#1474
#1475
Normally I search for things but considering this is a 30-page thread...
Are the actual SOS instructions for install posted anywhere in the thread? Specifically the Stage 2, Novi 1200 with the larger racing heat exchanger. I have it installed already, but I'd just like to learn as much as possible since I didn't do the install myself.
#1476
and...
https://www.scribd.com/document/3984...Install-Manual
#1477
At one point they say they will "prime the water pump" in a later step, but that step never appears.
#1478
https://www55.zippyshare.com/v/jxXp2F4U/file.html
#1480
Quick update -- I was finally able to get the SOS stage 2 kit with 1200 blower and 3.8 pulley installed. Having fueling issues over 7k, and the tuner suspects fuel pump issue (running what I believe is a walbro 255 installed by previous owner). Before the fuel issues, the car was at about 350ish hp and 250tq at about 7k rpm on a Mustang dyno. Tuner limited revs to 7k until I get a new fuel pump and we get the tune finished
Compared to my the old kw kit, the car seems to run more smoothly across the entire RPM range. The "coffee-grinder" sound from the blower is taking a little getting used to, but its overall more quiet than my rotrex setup. I'll have a more complete numbers once the fueling issues are solved and tuning is complete, but I am enjoying the SOS kit so far.
