SOS TS Max Turbo Kit Build Thread
Old Oct 21, 2013 | 07:41 AM
  #271
boostaddict712's Avatar
oh wow.... I'm quite perplexed as to why this setup is not hitting higher #'s on pump gas. Either way, I've really enjoyed following this thread and your review.
Old Oct 21, 2013 | 07:43 AM
  #272
Jmays2k's Avatar
Wow not what I was really expecting. Now do I go turbo/Supercharger mmmmm decisions decisions.
Old Oct 21, 2013 | 08:10 AM
  #273
pastoli's Avatar
V8 swap???
  #274
indi00's Avatar
Originally Posted by passmans2kny
sounds to me like the hp bug has bit u pretty hard, i see a big turbo set up in ur future
There is no way he'll make big power if he doesn't want to go E85 or race gas. Go E85 and boost to 30psi and that'll wake up the turbo.
Old Oct 21, 2013 | 08:30 AM
  #275
jordannn93's Avatar
OP your running 3" to 2.5" dual exhaust?
  #276
jordannn93's Avatar
Old Oct 21, 2013 | 08:34 AM
  #277
tx2K's Avatar
Wow! Not what I expected to see at all... Good luck with the sale though!
Next up...
Old Oct 21, 2013 | 08:37 AM
  #278
baZurk's Avatar
Hell yes!!
Old Oct 21, 2013 | 12:04 PM
  #279
rota92's Avatar
My guess is that it didn't make enough noise for him lol
That curve is dope. Build the motor and crank it and you'll be plenty happy with the top end output coupled with the nice curve down low.
If you end up tossing something with a 67mm+ compressor side and a massive hot side all of that goes away.
If you're never happy with F/I on these cars it's definitely time for something with a V8 lol
Old Oct 21, 2013 | 02:31 PM
  #280
ScienceofSpeed's Avatar
Former Sponsor
Please note as previously stated that the turbocharger used is a 35R hot turbine side, but the smaller 76mm cold compressor side. It is not the usual 82mm compressor found on the GT35R. If you look at the compressor map posted, the reason the power curve flattens out where it does is that the compressor has reached its limit at this pressure. I believe the customer did not to make 200 bhp with the fastest responding turbo possible (which was achieved). Using a larger compressor turbo, or a fuel that allows higher boost pressure with the same turbo, would achieve this - it has nothing to do with the kit, rather the turbocharger selected.
