Spacers needed for ID2000?
Old Mar 24, 2012 | 10:21 AM
1SlowSi's Avatar
Default Spacers needed for ID2000?
For my ID1000s I needed to use the little washers to ensure a perfect fit. Are these spacers needed for the ID2000s as well? When I line up both injectors side by side they are identical in length in every way which seems like they will need the washers as well. Thanks.
Old Mar 24, 2012 | 01:03 PM
D1sclaimer's Avatar
They do need the washers/spacers installed on the fuel rail studs.
Old Mar 26, 2012 | 05:52 AM
1SlowSi's Avatar
Thanks man they are running great now.
Old Mar 26, 2012 | 06:05 AM
liquidgsr's Avatar
did you plug these in to your factory fuel rail or aftermarket?
Old Mar 26, 2012 | 08:41 AM
1SlowSi's Avatar
Aftermarket AEM rail. They should work just find with the stock rail as well.
Old Mar 26, 2012 | 02:51 PM
BatmanCR's Avatar
Ive noticed my aftermarket rail was made for an AP1 and i bought AP2 injectors. I had adapters made. Otherwise the ap2 injectors should fit the oem ap2 rail and depending on what fuel rail you get you may or may not need adapters.
Old Mar 27, 2012 | 03:58 AM
DFWs2k's Avatar
It's about 00-05 vs 06+, not ap1 vs ap2.
Sent using free Tapatalk - Android FTW
chtmatthew
Feb 4, 2019 09:49 PM
Suzuka_Joe
Nov 6, 2018 09:54 AM
brax_1
Jun 7, 2018 12:00 PM
ChefJ
Jan 15, 2009 04:57 AM
speedy4cyl
May 27, 2004 08:53 PM
