Spal fan
Old Aug 12, 2016 | 02:01 AM
Jaspah's Avatar
Default Spal fan
Hi,
I installed a single spal extreme radiator fan a while ago. But it seems that the original fuse and relay won't work with this fan. I think it needs more amps than the fuse can handle.
When the engine is off, and I manually switch the fan on via my laptop (aem ecu) I do hear the realy clicking... but I think the fuse is allready gone.
What kind of relay and fuse do I need for this fan? And where can I buy one?
Thanks!
Jasper
Old Aug 12, 2016 | 07:33 AM
Jin_SK's Avatar
SPAL Extremes run off a special HO relay w/ 40 amp fuse (PN: FRH-HO-KIT).
Old Aug 12, 2016 | 06:56 PM
riceball777's Avatar
spal extreme performance fans need a special high output relay as well as a special harness and fuse kit that lets you wire the fan straight to the battery. You will also need a fan soft start controller to control the fans so that they dont start at 100% power and stall your engine.
here are the 3 things you will need
this is the spal high output relay with the wire harness
http://www.ebay.com/itm/NEW-SPAL-HIG...lWgqyw&vxp=mtr
This is a fan control you will need so the fans dont stall your engine when they start.
http://dccontrol.com/constant_temper...ontrollers.htm
Old Aug 13, 2016 | 02:02 AM
Jaspah's Avatar
Do these fans draw so much amps that it will stall the engine when it comes on?
That's pretty sick
I have just one 12'' twisted blade fan
Old Aug 13, 2016 | 10:59 AM
Jin_SK's Avatar
That's pretty sick
Two certainly can, the amp inrush is pretty ridiculous. I got a 83F capacitor to compensate. When they turn on it's like gale force winds
Old Aug 13, 2016 | 03:25 PM
i also have 2 spal extream fans and they will stall the engine when they kick on from off to full 100% on. You will need either a capacitor or some type of soft start fan controller than do not start the fans at 100% power. I have done both and i recommend the fan controller from www.dccontrol.com This will start the fans at 10% power and will slowly add power as the water temp goes up.
Old Aug 13, 2016 | 04:40 PM
5thgen's Avatar
Has anyone tried the spal brushless fans? Supposedly they have a soft start built into them. I don't know if they can be controlled by just a relay (on/off), or if they need a pwm signal. But they have been out for a couple years, but I can't find too much info on them.
Old Aug 14, 2016 | 12:55 PM
Jaspah's Avatar
Is a soft start also needed with just one fan?
Old Aug 15, 2016 | 10:30 AM
CoolGuy094's Avatar
I would wager that yes, some type of soft start would be needed or at least highly recommended. Using a capacitor may be a better option with just one fan to keep costs a bit more reasonable, though. My dinky normal SPAL fans have a noticeable effect on the idle of the car when they cut on, so I could only imagine the load that these extreme fans put on the engine.
Old Aug 15, 2016 | 01:59 PM
Jaspah's Avatar
Ok, I will fix something than. Thanks!
cheddaboy
May 9, 2016 09:53 AM
p0staboy
May 13, 2011 03:42 PM
Spec_Ops2087
Jun 16, 2010 06:04 PM
s2kVTAK
Nov 18, 2008 04:06 AM
Bass
Jun 14, 2008 04:29 PM
