Which Spark Plug?
Which plugs would you guys recommand on a Vortech S/C running 9lbs?? I'm running the Denso IK27 and it is time to replace them since it is getting old.
The consensus on here seems to be either NGK 7173's (1 range colder then stock) or NGK 7405's (2 colder then stock) depending upon the amound of boost/power you are looking to run. I'm currently running the 7405's, but just know that you need to change them every few thousand miles.
Im gonna get these for my 7psi pulley. still on stock now.
Originally Posted by jwkim,May 16 2006, 04:26 PM
Get NGK 7173(heat : 8).
Originally Posted by r_duff,May 16 2006, 08:29 PM
define 'few thousand miles'
Originally Posted by WindchaserS2K,May 17 2006, 10:29 AM
well seem like you are running quit a bit more boost then I do and only using 1 step colder and I guess that's what I need then thanks alot
but with 9 psi I would run 7173.
I change them every oil change(around 5000 mile)
