Spark Plug Gap
Old Jan 13, 2015 | 02:24 PM
jdrsxtypes's Avatar
Default Spark Plug Gap
Wanted to see what gaps people are running around the 650hp mark. I currently have to run .16 so that it won't blow spark out which is a really small in my opinion. I am on a 2006 stock block with around 41,000 miles, stock coil packs, NGK 9's, and E85. Also has anyone tried running RSX Type-S coil packs. It seems that their stock coil packs are a bit stronger. The olny reason I ask is I would like to open the gap a little more to try to get a litte better MPG and power.
Old Jan 14, 2015 | 01:50 PM
Manus2kpr's Avatar
hi there i have been building hondas for a very long time and for what i have seen it depends on boost!! how many boost are you using?
Old Jan 14, 2015 | 03:50 PM
jdrsxtypes's Avatar
I am running 23psi.
Old Jan 14, 2015 | 03:53 PM
VitViper's Avatar
NGK 2669, 28psi .018" gap. Using OEM 06+ Civic Si coils (K series). These coils have been tested and tried in 1000hp cars, the gap you are using is perfectly acceptable given the appication...
Old Jan 14, 2015 | 04:21 PM
jdrsxtypes's Avatar
What year is your s2000 VitViper.
rob2.2
Aug 17, 2011 03:21 AM
08s2000CRbackinblack
Jun 22, 2011 07:57 AM
RL1924
Dec 21, 2009 05:21 PM
batikan
May 16, 2006 10:35 AM
SSS2k
Feb 26, 2004 05:22 AM
