spark plugs...
Old Oct 1, 2008 | 12:25 PM
AndyFloyd's Avatar
Default spark plugs...
I have searched and there are just too many different plugs that people are using. I am going to be running a maximum of 12psi on my pfab/ custom turbo setup...it has a log manifold so im guessing 400whp will be the maximum that im gonna get out of it. I was thinking a NGK V-Power copper plug thats 2 heat ranges colder, what plugs are you guys using? THANKS!!!
Old Oct 1, 2008 | 01:30 PM
powerneedy's Avatar
ngk r bkr7e
Old Oct 1, 2008 | 01:34 PM
JoeyBalls's Avatar
my Greddy plugs are $80.00..............way toooooo much
These were recommended to me, by Courage.
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=3252
They ARE SO MUCH cheaper, only thing is they are Copper, I dont mind changing them more often (every oil change), but would I be better off sticking with Irdiums, or do they just last longer?
I will be getting tuned wit the METH in NOV so I will have my plugs in by then
Old Oct 1, 2008 | 01:46 PM
s.hasan546's Avatar
Originally Posted by powerneedy,Oct 1 2008, 01:30 PM
ngk r bkr7e
r those the non-resistor ones?
Old Oct 1, 2008 | 03:09 PM
TRBOKEV's Avatar
Get the NGK BKR8EIX.
NGK Iridium plug, resistor type, one heat range colder than stock (8).
They cost around 7-8 dollars each and i use them and really like them.
Whatever you do dont get Denso iridiums, they are horrible.
Old Oct 1, 2008 | 03:45 PM
ERL_S2000's Avatar
I step colder should be fine.
Old Oct 1, 2008 | 04:01 PM
JoeyBalls's Avatar
pre-gapped, if not how do I gap irdiums, and what gap?
Old Oct 1, 2008 | 05:16 PM
SgtB's Avatar
They should be dead-on .030, just gauge them to be sure. If you do adjust them, DO NOT even touch the tip. Iridium is hard, but it's super brittle.
Old Oct 2, 2008 | 06:06 AM
Revenge's Avatar
Unless you are using a tubular I would think you are going to be around 350-375 hp at 12 psi.
But I hope you hit 400!
Old Oct 2, 2008 | 04:27 PM
AndyFloyd's Avatar
ngk r bkr7e
this is the ngk v-power copper plug correct? If so, thank you!
