Spoon exhaust adequate for turbo
Old Jul 6, 2010 | 04:30 PM
VTECSTYLE's Avatar
Default Spoon exhaust adequate for turbo
Okay well im in the process of turbo'ing my ride and do you think the spoon exhaust will do okay or should i look into doing a 3inch i know of course im gunna get some nice gains from a 3 inch my hp goals are high 300s with t3/t4 turbo .63/.60 if i can hit 400 ill be happy.
Old Jul 6, 2010 | 04:54 PM
AusS2000's Avatar
Quick note: it ain't the brand name that's important it the flow.
I'm not up on what Fork produce but I expect it is freer flowing than stock and your power goals are fairly conservative so I expect it will do.
But I also expect you will very quickly want more and part of that upgrade will be a 70mm or larger exhaust (ridiculous name brand or not).
Old Jul 6, 2010 | 09:31 PM
PsykotiK's Avatar
spoon is only 63.. u might as well run stock
Old Jul 6, 2010 | 09:35 PM
AusS2000's Avatar
I'm guessing if it's a single and flow through muffler it may be slightly better than stock.
In summary, stick with whatever exhaust you've got but if you want improvements, go larger.
Old Jul 6, 2010 | 11:18 PM
VTECSTYLE's Avatar
Well i bought the car with the spoon exhaust and i know that free flowing is the key with turbo. well im gunna be using it for now but 3 inch will be in this cars future.
Old Jul 6, 2010 | 11:20 PM
AusS2000's Avatar
Sounds like a sensible plan.
Old Jul 6, 2010 | 11:45 PM
Deception's Avatar
just get the 3" exhaust (& downpipe) now, why re-tune when your get tired of 300whp after a week
Old Jul 7, 2010 | 04:09 AM
teamvalorracing's Avatar
do what i am doing and run a 3"dp to Y-pipe with one leading to oem exhaust and the other portion terminating with a 3" electronic cut-out!
all the massive hp of a open 3" dump at the flick of a switch, then when your done blasting, flip the switch again and back to stock sound levels for cruising.
best exhaust system of all time IMO.
Old Jul 7, 2010 | 09:16 AM
wisdom's Avatar
Sell me your spoon exhaust.
Old Jul 7, 2010 | 10:14 AM
camuman's Avatar
and buy my asura exhaust!
