Stage 1 CT or SOS SC
Hey all,
I know this has been talked about in the past, but it appears that all the previous post are at least 5 years old. So I'm looking for opinions on my personal needs and changes that have happened with these kits in the better half of a decade. In the future I would like to go with a stage 1 kit and avoid a stand alone engine management system due to cost and issues passing emissions. Although I may opt for the stand alone in the future if I want more power. At what WHP levels is the differential in danger? It would likely be a few years before I would upgrade if ever. So it appears that the SOS kit is easier to upgrade and allows for Vtec engagement to be lowered to ~4500 RPM. Does the CT kit lower Vtec engagement? It appears that most CT owners have had great reliability with their kits, is the same true with the SOS set up? FYI I have a 2001 with ACT PP, ARP bolts, upgraded banjo bolts, and AP2 retainers.
Hey all,
SOS and CT kits aren't very hard to install/remove. If you upgrade anything on the CT kit, the chances of passing smog is slimmer, but still do-able. Your call if you want that CARB showing or make more power out of the box.
doesn't the SOS kit require an EMU? CT can be used without an EMU, but won't make as much power -obviously until you tune it with an EMU and some upgrades.
CT and SOS with NOVI1200 will offer similar power levels.
Having SMOG legal and carb approved kit is a huge plus, so that's a pro for CT-Engineering kit.
SOS' pro is that their aftercooler is supposedly more efficient (who knows if that's true), but I like the sound of lower AITs.
I'd be torn too.
I'd be torn too.
Id personally go SoS if I had to do it over again. CT DOESNT like money, wont speak to anyone outside an authorized dealer and can take MONTHS to make a part of fab a kit together where as SoS can have whatever you need in the mail that very day.
This. They'll sell you anything you need, from a nut and bolt, to a new mounting plate. Customer service is incredible
Not even a questions, SOS all day long! Amazing kit, awesome customer service. You get what you pay for these days remember that.
You can get there stage 1 kit, and get the plug and play map, runs 6 psi and makes 300hp on 93oct. If you want more, go Kpro, EMS, or infinity.
rmerchant3
Forced Induction For Sale
Apr 1, 2017 10:45 AM
