stethoscope vs. knock volt limit?
Old Dec 28, 2010 | 01:45 PM
purekoryo's Avatar
Default stethoscope vs. knock volt limit?
Has anyone roughly correlated what would be the knock volt limit vs. what you heard on the stethoscope when tuning? In other words, as soon as you heard a moderate knock, what has the knock voltage range been?
Old Dec 28, 2010 | 02:38 PM
hondabim's Avatar
i will also like to know whats a safe limit on the knock volts?
good question
Old Dec 29, 2010 | 07:51 PM
purekoryo's Avatar
Originally Posted by Evans Tuning,Dec 28 2010, 05:45 PM
Knock voltage vs what you'll hear out of a set of knock headphones can differ quite a bit. I have seen knock voltage ringing around 2 volts, and not heard audible knock until 3.5 volts at high rpm. Just depends on how much noise the engine generates. A good knock filtration in the software makes all the difference for a usable knock input for knock control. The series 2 AEM EMS has a frequency aspect that really filters out a ton of noise on the knock signal. I am very impressed with how well it works.
Can you go into more detail on the frequency and how to filter the knock? I have a series two aem ems and I just set the thresh hold to 2 volts for knock control; it will retard 2.7 degrees / volt above the threshhold I believe.
Old Dec 31, 2010 | 07:38 PM
InductionPerformance's Avatar
The first Series 2 01v17 I tuned I loved the new knock control. V1 knock control was pretty good. The Series 2 is great.
Curated Content Editor
Apr 2, 2019 11:48 AM
JonBoy
Oct 29, 2015 01:34 PM
rikhemi
Apr 4, 2005 04:21 AM
all-trick'd-out
Apr 12, 2004 08:43 AM
