Stock fuel line size
I assume several of your FI guys have done this. What size is our oem hard fuel lines. I want to come off them with a tube fitting to AN. I have seen conflicting information. Thanks
Are you speaking of the hard lines? Feed and Return. I ready somewhere about it being a -5AN. I wonder what the return is?
Hard lines are both cut off at firewall. I just dont want to half ass it and want to use the correct fittings, instead of clamping anything, ect.I will be doing a completed build thread soon. Thanks for the help.
https://www.s2ki.com/s2000/topic/702...d-for-600-whp/
Too bad you are not closer or I would give you the modified line I have from the above build.
Same for the return side?
picco97
Oct 24, 2016 01:41 PM
