Stock Head Bolts
Old Jun 1, 2010 | 05:56 AM
JuicedS2K's Avatar
Default Stock Head Bolts
Ok, I have been searching and searching and no one has a straight answer. I just received brand new OEM head bolts and plan on installing my 3mm head-gasket next week.
People say the head will lift with stock head bolts about 16 psi...
Fact or fiction?
I will be running around 20 psi.
Old Jun 1, 2010 | 05:58 AM
spectacle's Avatar
Who are these 'people'? They're misinformed.
Old Jun 1, 2010 | 06:03 AM
JuicedS2K's Avatar
Old Jun 1, 2010 | 06:07 AM
Irishflame27's Avatar
they have been pushed over 30+ psi with no lifting
Old Jun 1, 2010 | 06:09 AM
camuman's Avatar
this is a tough one. spoolin has arp head studs and has had zero problems i beleive.
however, i dont remember reading anyone lifting a head on a stock block'd stock headbolt car at 20psi. honestly, just do the head bolts, you already went a step further then most and replaced the bolts, most reuse as long as they are in spec.
worst case call evans and ask him what he would do. i wouldnt be surpised if he says just use oem bolts.
Old Jun 1, 2010 | 09:04 AM
ChefJ's Avatar
fiction. I ran at 22ish pounds for about 8 months on factory bolts and a 3mm hg. Mine were prestretched and reassemble twice before that though, and that may attribute to my success. I just had the motor built and the compression lowered the right way so i will be going with arp studs now.
Old Jun 1, 2010 | 10:24 AM
siadam's Avatar
25psi here stock everything.
If you see, Spoolin made that post in 2007, we have learned ALOT in the past 3 yrs.
Old Jun 1, 2010 | 11:32 AM
mys2k3's Avatar
I'm on 20+ lbs with new oem bolts.
Old Jun 1, 2010 | 11:59 AM
Revenge's Avatar
I am at 20psi and they re-used mine.
Old Jun 1, 2010 | 01:26 PM
s2kswe's Avatar
As a rule of thumb, its adviceable to avoid reusing bolts that are torque + angletightened north of the permanent deformation point/stretching limit. These bolts have worse properties the second time they are used. This is only fact tho. Use at own risk .
