Supercharged S2000 check engine light
Old Mar 23, 2009 | 02:05 PM
BLAKANEZ AP1's Avatar
Default Supercharged S2000 check engine light
I need some help, my check engine light came on randomly the other day
Here is my setup:
2003 s2000; 43,000
Comptech supercahrger w/ aftercooler
Invidia testpipe
Invidia catback exhaust
Just wanna know wat u guys think the problem might b, it came on two days after I installed the testpipe
Old Mar 23, 2009 | 02:13 PM
Slows2k's Avatar
Get a code 1st.
Old Mar 23, 2009 | 02:26 PM
Vette2K's Avatar
We don't need a code. We should just guess.
Old Mar 23, 2009 | 04:07 PM
Mrfixit687's Avatar
Shouldnt people learn by now not to post up a cel thread if they dont have the code.
Old Mar 23, 2009 | 04:14 PM
Randizzle88's Avatar
buy a scanner
Old Mar 23, 2009 | 04:34 PM
CodyLX450's Avatar
I'm going to guess its the test pipe telling you the 02 sensor connected to it just started complaining.
Old Mar 23, 2009 | 04:56 PM
BondoBuilder's Avatar
x2
Do you have two anti-foulers stacked, or the CEL fix?
Get a code to be sure.
Old Mar 24, 2009 | 04:37 AM
S2K Freak's Avatar
Buy a spark plug gapper and screw your O2 sensor into it that way it gaps your sensor out more. If I can remember, It's a 14mm gapper. You can get it at Auto Zone for a few bucks. Then it wont throw the check engine light anymore. You'll have to bore out the hole on the end of it so your sensor will fit. I had to do that to mine after I installed my test pipe. It's just your O2 sensor reading more flow but by gapping it, you wont have that problem anymore.
Old Mar 24, 2009 | 09:43 AM
s2000Junky's Avatar
Yeah its likely the test pipe, get another extended bung and double them up to pull the 02 sensor out of the exhaust path far enough.
Old Mar 24, 2009 | 12:04 PM
thanks s2k freak I'll give that a try
