supercharger boost...
Old Aug 8, 2005 | 08:50 AM
lsportlex's Avatar
Default supercharger boost...
What up all S2000ers,
i just freshly installed my vortech supercharger and it seems as if its not boosting till about 6000 rpm. Considering that my redline is 8000, thats not to much of a power band. I was under the impression that a supercharger should give boost instantly but for some reason my supercharger boost like its a turbo... Is there something wrong or is this how the vortech blower gives boost????
Old Aug 8, 2005 | 09:04 AM
Sideways's Avatar
Did you get the '04-'05 kit with the 4-1/2 inch pulley?
Do you have a boost gauge or are you just about the boost?
The boost is very linear and starts around 3000 rpm. It really feels good towards redline.
I suggest if you don't have a boost gauge that you get it dynoed and they will be able to tell you what boost at what rpm you are producing.
Old Aug 8, 2005 | 09:35 AM
Scorpion's Avatar
Yes a supercharger will boost instantly, but it will only be a pound if that. Boost from a SC is linear meaning you are always making boost but you don't hit max until you are at redline. As Sideways mentioned, if you are not running the 04+ pulley you will only be making around 4psi on a Comptech and maybe 6psi on a vortech, which isn't going to feel strong.
And I would definitly pick up a boost gauge...even a cheap one from pep boys will atleast let you see if you are in fact making boost.
Old Aug 8, 2005 | 11:11 AM
lsportlex's Avatar
i do have an AutoMeter boost gauge, it starts boosting at about 4000 rpm and the higher and higher in rpm i go the more and more boost there is. i do also have the 04 05 vortech kit..i just thought there would be "instant" boost with a supercharger versus a turbocharger.....
thanks for the info
Old Aug 8, 2005 | 11:41 AM
SIIK2NR's Avatar
thanks for the info
The boost is instant.....but a Turbocharger will achieve max boost at a much lower RPM...which is what you seem to be looking for...
Old Aug 10, 2005 | 05:20 AM
Tinker219's Avatar
thanks for the info
if this were a Roots blower, then yes. Centrifugal style blowers are "laggy" in reference to peak power vs RPM.
Old Aug 10, 2005 | 02:40 PM
Slows2k's Avatar
Centrifugals aren't laggy. they are Linear. The more RPM you spin them the more boost they make. Unless you are exceding Max impeller speed, which you won't do on a stock SC kit.
Old Aug 11, 2005 | 04:32 AM
MickeS2K's Avatar
What happens if you overload Max impeller speed? Is there anybody
who has gone over max impeller speed (53000rpm)?
Old Aug 11, 2005 | 06:09 AM
Sideways's Avatar
The air behind the blade will cavitate and you will loose pressure. If the tip of the blade speed exceeds the sound barrier there will be a little sonic boom in your engine compartment. BOOM
derek14
Oct 28, 2008 06:38 AM
kstokell
Dec 1, 2005 04:16 PM
Vortech
Jul 28, 2003 01:35 PM
