Supercharger with Front Mount Intercooler
Old Jan 12, 2007 | 03:39 PM
  #21
MugenRioS2k's Avatar
unbiased technical data
Old Jan 13, 2007 | 08:35 AM
  #22
S2000_Europe's Avatar
Originally Posted by bc02,Jan 13 2007, 12:10 AM
I looked into getting bigger water pump last night to no luck as the next size up is WAY BIGGER and draws almost 9 AMPS at peak compared to our 2.2 draw.....but does flow 5 times as much water the Johnson Marine pump we currently have.....
i am going to bite the bullet and buy 2 more water temp gagues and install them in the in-line going to the Comp. Aftercooler and one in the return line feeding back down after the Comp. Aftercooler......so i will catch both temps telling me what the water temp is before and after so i can see how much they vary.......the 1st will let me know how well the Tech 2 Radiator is cooling the water as it will heat up going through the Aftercooler and 2nd will tell me how high the water temps are getting.
If i am not happy with the readings i will switch back to the little Comptech unit and see how it compares. I am really after Facts here and not just feeling the Aftercooler and makeing a judgement based on the hand temperature gague.
you should do the test with the Comptech unit too, so you will know which is better and temp differences between both radiators
Old Jan 13, 2007 | 10:03 PM
  #23
bc02's Avatar
ya if i feel like installing and un-installing both units which is going to be a pain in the butt.....just to prove a point.....if i am not happy with the Tech 2 unit i will.....because it is pretty heavy filled up with water and also blocking air going to my oil cooler and radiator sittin out front there.....the comptech rad is really little and light plus it doesn't block air to my oil cooler which is got me concerned now......so i will have to wait and see how things unfold in the next few months for me.....right now i am installing TEIN SRC's and have to get an alignment done 1st....then off to the dyno for tuning
Old Jan 17, 2007 | 12:05 PM
  #24
Sarek's Avatar
subscribing, any new info yet?
Old Feb 11, 2007 | 08:09 PM
  #25
info/numbers???
Itchy Dick
Feb 17, 2008 01:46 PM
batikan
Aug 6, 2006 09:19 PM
161MPHTOPSPDS2K
Feb 25, 2006 11:22 AM
r_duff
Aug 4, 2005 04:21 PM
Silver S2k4
Feb 28, 2005 08:06 AM
