Supercharger rubbing on crossmember
Old May 19, 2015 | 07:00 PM
99SH's Avatar
I was never happy with the clearance between the blower and the subframe. I was rubbing the bottom side of the aftercooler as well which made a nice gouge in the aluminum.
Old May 19, 2015 | 08:06 PM
leoxle's Avatar
Thanks everyone for the comments, I'll definitely have a look at the motor mounts, hopefully that fixes the problem.
Old May 20, 2015 | 06:22 AM
Road racer's Avatar
Originally Posted by Sideways
If you are getting new mounts, check out the Vibrasonic mounts. Fantastic action and they look good too.
After I broke both OEM mounts, I installed the Vibra-Technics mounts. I really like them and have no issues with the harshness of engine idle. I will point out that the Vibra-Technics seemed to lower my motor about 1/8" from the OEM mounts. I did not use the OEM heat shields (sandwiched between the top of the mount & the motor) which is ~1/8" thick. If you (or anyone) tries these mounts with clearance problems, then you might need to stick a 1/8" thick spacer in there. Plenty of room with the threads to add even more height if you need to.
I have a Vortech SC and no clearance issues without the spacer. Like iDomN8U stated above, we have to notch out the crossmember to put in the long pulley bolt on our kit. With the engine a tad lower, I did not want to notch this out more. So, I simply loosen the motor mount bolts on the bottom and raise the motor with my jack ~1" then lower it back down once the bolt is in.
My link
daileyboy81
Aug 17, 2015 01:36 PM
daileyboy81
Aug 17, 2015 11:05 AM
CJB22
Jun 15, 2010 03:17 PM
GT_NFR
Dec 18, 2007 02:22 PM
