Surface temps on my turbo manifold
Old Jul 14, 2007 | 12:51 PM
2QYK4U's Avatar
Thumbs up Surface temps on my turbo manifold
I have had some issues with heat coatings on my Full-Race manifold cracking/blistering. I've had the manifold coated twice by a company called HPC and the coating failed both times. I recently had the the manifold re-coated by a local company and it is starting to fail as well. So, today I used a pyrometer and measured the outside surface temperatures of each runner while at idle. Here are the results:
Runner #1 - 505 deg F
Runner #2 - 540 deg F
Runner #3 - 550 deg F
Runner #4 - 560 deg F
I've already had runner #4 tapped for my Defi EGT gauge, but I haven't had the gauge hooked up as of yet so I am unable to measure the EGTs within the runner itself. Any guesses as to what the internal EGTs are while at idle?
Old Jul 14, 2007 | 01:06 PM
PeanutButter's Avatar
800 plus
Old Jul 14, 2007 | 01:24 PM
2QYK4U's Avatar
Originally Posted by PeanutButter,Jul 14 2007, 02:06 PM
800 plus
If that held true, there is no way the 2000 degree coating should fail, correct? It really seems like I am simply getting a poor quality coating and that my EGTs are actually ok.
Old Jul 14, 2007 | 01:34 PM
AirborneS2K's Avatar
I'd tell HPC to touch their toes...
BlownAP's Avatar
I highly doubt your manifold is touching 2000
Old Jul 14, 2007 | 01:38 PM
2QYK4U's Avatar
I am in the process of filing a claim with HPC. I wasted about $400 with them.
Old Jul 14, 2007 | 01:40 PM
2QYK4U's Avatar
As do I...even under WOT for prolonged periods.
Either way, within a few months I am going to remove the turbo system and send the turbo manifold and turbo to Jet-Hot for their Jet-Hot 2000 coating (good up to 2400 degrees). This is going to cost me about $500 for their coating (both parts), plus labor to remove/re-install the turbo, but I want to be done with this crap.
Old Jul 14, 2007 | 01:41 PM
passmans2kny's Avatar
great, im shipping my manifold and turbo there as we speak, i was getting the 2000 coating as well
Old Jul 14, 2007 | 03:05 PM
Spec_Ops2087's Avatar
The car will actually run much hotter at highway speeds then it would WOT for long times.
Even with that said, I've NEVER seen my EGT gauge go past ~1320F and that was at 85mph on the highway. During WOT I stay between 1100-1200 degrees, nothing more
Sounds like the coating is a peice of sh*t
Old Jul 14, 2007 | 03:17 PM
2QYK4U's Avatar
I hear what you are saying.
Full-Race is supposed to provide me with expected EGTs for their manifold. Hopefully I will get my EGT gauge hooked up soon!
