swapping 07 into my 01 with CT kit
Originally Posted by devs2k,Mar 19 2009, 12:27 PM
As long as you don't use the 07 cylinder head, then you are fine. No need to change any sensors.
However, this does opening up that nice stock motor
Originally Posted by s2000Junky,Mar 19 2009, 03:33 PM
Yeah I dont want to swap heads, and I do want to be able to use the ap1 ecu to pass emissions. Thanks for that information!
So I want to be clear, and 04/05 if I want to use a f22 and that should be strait forward same as f20 with no issues?
Thanks guys!
Thanks guys!
Originally Posted by Soul Coughing,Mar 19 2009, 12:38 PM
i am currently running an ap2 in my car. Biggest issue i remember was getting the fuel line to work. I needed to buy a ap2 fuel line from the firewall to the motor.
Originally Posted by devs2k,Mar 19 2009, 12:49 PM
If you buy the Hondata Kpro now, you can swap in that 07 entire motor (still use the 01 intake manifold, injectors, etc)....no need to swap heads
you would be buying the kpro designed for 04-05 cars
Originally Posted by s2000Junky,Mar 19 2009, 04:51 PM
Im not swapping in a k pro stand alone. I am swapping in a hondata intake manifold gasket. Sorry if there was a missunderstaning there
Yea, I was just saying if you really wanted to swap in that 07 long block, you could with the Kpro standalone.
Honestly, as long as your f20c is fine, you might as well spend the money on injectors/pulley/aem or kpro rather than a new motor..
