Thicker gasket or not?
Old Jan 5, 2011 | 08:23 PM
Titounais's Avatar
Thumbs up Thicker gasket or not?
Hi guys, I wonder if I should put a thicker gasket to lower the compression with my setup...
Comptech with aftercooler and around 10 psi of boost.
I want to take my car to the dragstrip too...
Some guys says that I can leave it stock.
What do you think?
thanks
Old Jan 5, 2011 | 08:29 PM
donaldmejr's Avatar
10 psi.... just leave it stock CR you should be able to handle as high as 13-14 psi on 93 octane.
Old Jan 5, 2011 | 08:36 PM
riceball777's Avatar
Stay with the stock gasket
Old Jan 5, 2011 | 08:43 PM
Titounais's Avatar
what is CR? the latest edition? or something that I ignore? LOL
I tought there were only two diffent engine F20 and F22
Old Jan 5, 2011 | 09:11 PM
DFWs2k's Avatar
cr = compression ratio, ie, the main thing that a thicker hg changes
Old Jan 5, 2011 | 09:13 PM
DFWs2k's Avatar
Old Jan 6, 2011 | 05:33 AM
dsddcd's Avatar
What do you think?
thanks
Leave it stock and up the boost to 12-14PSI if you are looking for more power.
Old Jan 6, 2011 | 08:21 AM
Revenge's Avatar
no leave it
Old Jan 6, 2011 | 09:24 AM
h1gh0ct4n3's Avatar
on;y point in putting lower compression is to up the boost....
if your not gonna up it you'll do nothing but lose power so yea def keep it stock.
Old Jan 6, 2011 | 09:55 AM
passmans2kny's Avatar
i already went this route and I'm back on a stock hg, unless ur going for over 500 hp don't touch the motor
