For those of you with Greddy Profec series BCs
Old May 21, 2007 | 06:51 PM
Spec_Ops2087's Avatar
Default For those of you with Greddy Profec series BCs
Well before I send my entire unit back due to a bad solenoid (I think), I want to be completly sure that it is the solenoid and not just the way it is wired.
For an external wastegate setup, the manuel says for the COM port to go to the wastegate and the NC port to go to the boost source. When I have the vacuum lines wired that way, my wastegate will NOT open at all (when it should open to the spring psi) however when I stick my manuel boost controller back on, it works perfectly fine.
Now being curious, I decided to test the solenoid out by myself just blowing through the holes. If I blow through the NC hole, it is blocked completly which I guess is why it doesn't open the wastegate. If I blow through the COM hole, I feel air coming out the NO port. If this is the case, why the hell do the instructions say to go through the NC port when, common sense tells me, to hook it up to the NO port that obviously sends air to the COM port????
For the record, the manuel says to hook up the NO port and COM port when using a actuator style system (not external wastegate).
So I guess my main question is, for those of you who have this darn thing actually working, how are the ports on your solenoid set up with the vacuum lines?
Thanks,
Jonathan
Old May 22, 2007 | 04:32 AM
bump, I'd like to find out today before I return it.
Old May 22, 2007 | 11:12 AM
Reborn56's Avatar
More then happy to let you use my solenoid from my BC
Let me know.
Marcus
Old May 22, 2007 | 05:11 PM
I think I found my problem. The picture in the directions has a pretty big mess up that would fool anyone. Apparently the boost controller attaches to the TOP of the wastegate despite what the picture in the manuel shows...Getting up early to go to NAPPA to get some vacuum line and test out the new configuration. We'll see what happens.
Old May 22, 2007 | 05:41 PM
s2guru's Avatar
where did you put the BS in the car? i'm lookign at the same BC
Old May 22, 2007 | 07:06 PM
under the steering wheel and a little off to the left near the hood release switch.
Old May 22, 2007 | 07:48 PM
s2guru's Avatar
=/ i have my defi control unit there, where can i put the BC?
Old May 23, 2007 | 04:06 AM
The other side maybe? Its your car, figure out a good spot that you want it
Spec_Ops2087
Jun 7, 2014 07:58 AM
blueap2
Aug 26, 2009 06:56 PM
JoeyBalls
Aug 23, 2009 05:36 PM
sbrodacz
May 10, 2009 12:49 PM
Spec_Ops2087
May 5, 2007 08:57 AM
