Tial BOV and wastegate spring
I bought a used TIAL Q BOV AND 44mm Wastegate and I am not sure what spring is in there. What springs should put in. Looking to run around 7psi of boost in 1st and 2nd gear and higher in the other gears, but not sure how much. Most likely it will be close to 20 since im shooting for 600 on E85. I am using boost by gear with the MAC solenoid installed.
Do you need springs? I have a few springs for the TiAL MVR (44). Let me know which version you have; the following is the spring chart:
http://www.tialmedia.com/documents/MVRspc.png
Unfortunately I don't. I think I threw away the box he gave me. I might just end up buying the springs I need just to be sure. I have a box of mixed springs in a bin at my friends that I will look through.
So on the chart for the wastegate it shows green, blue for the 8.7 does that mean I need to use both? Kyle can I pick up the springs from you sometime this week...not sure which ones go with the BOV and which go to wastegate so I plan on getting new ones or ones I know the colors are.
