Timing Cover Turbo Oil Return
Old Feb 27, 2012 | 09:20 AM
  #21
illestrolla's Avatar
Bumping this up, I'm about to bite the bullet and get drilling on mine.
Anyone else have success with this method?
Old Feb 27, 2012 | 09:31 AM
  #22
USAF_S2K's Avatar
im gonna do it this way, theres no negative to the setup. its perfect and will look pretty slick with some an lines.
Old Feb 27, 2012 | 09:40 AM
  #23
H4RD ON's Avatar
Doing it this way too. Seems like the perfect place for routing it with sidewinder.
Old Feb 27, 2012 | 09:56 AM
  #24
Timing cover return crew whaaaat!!
Ill post some pics as soon as I start gettin after it in the garage.
Old Mar 25, 2012 | 08:18 AM
  #25
My cover is en route from Deception right now!
I will be tigging it up when it arrives and will post pics
Old Mar 25, 2012 | 09:11 AM
  #26
gsx2004's Avatar
I've done it this way with a mase turbo kit and it has done fine for a year now. Its just a drain at the end of the day. Just need to make sure where ever it is that it doesn't have a chance to back up and this timimg cover spot is great. Alot easier to check for leaks and i used alot less heat wrap thats for sure.
Old Apr 25, 2012 | 06:15 PM
  #27
s2knoob89's Avatar
Added a couple updated pics from my new sidewinder setup.
Old Apr 25, 2012 | 09:04 PM
  #28
05TurboS2k's Avatar
Originally Posted by MegaTRon
how hard is it to remove the timing cover?
It's quite easy, you can actually do it without removing the head gasket but you'll need to drop the oil pan instead. Then do a good job with the sealant when you re-assemble it to be sure it doesn't leak. I did one just last week for a friend.
I don't see what the problem is with taping the pan instead but to each their own.
Old Apr 29, 2012 | 08:41 AM
  #29
05TurboS2k's Avatar
Why not pull oil from the pressure switch? That's where mine comes from, location is great as it's out of the way and keeps the hose just 6 inches long or less in my case.
Old Apr 29, 2012 | 08:35 PM
  #30
Bigfootexpert's Avatar
EXCELENT JOB
