Too much boost?
Old Oct 21, 2010 | 07:24 PM
Wick3d3vo's Avatar
Would you need to change out your HG and head studs for that setup?
Old Oct 21, 2010 | 07:28 PM
neoleooo's Avatar
Originally Posted by s2k dre,Oct 21 2010, 11:44 AM
I wouldnt go more than 20psi on stock compression. And 14psi doesnt mean anything unless u give us ur turbo size.
Compression is actually lower from a 2mm head gasket. Turbo is a Garret ball bearing GT3076
Old Oct 21, 2010 | 07:33 PM
neoleooo's Avatar
Old Oct 21, 2010 | 07:37 PM
EternalLx's Avatar
Get rid of the RC650.. you'll be at 100% duty cycle at 9 or 10psi.
ID1000cc
Old Oct 21, 2010 | 07:41 PM
camuman's Avatar
ID1000cc
agreed. esp since 06+. also, might want a KBAP. not too mention, rc650s are pure trash. i run them, and i hate them.
Old Oct 21, 2010 | 08:12 PM
siadam's Avatar
Originally Posted by neoleooo,Oct 21 2010, 07:17 PM
Garret GT3076
I did that on a 05 stock s2k for a yr.
On 93 we only pushed to 10/11 lbs and beyond that we used 110, maxed out around 15/16 lbs and 509whp.
Btw, I've got a KB BAP for sale, almost brand new. Link in sig.
Old Oct 21, 2010 | 08:36 PM
neoleooo's Avatar
I actually did. 2mm gasket and arp head stud. I talk to lots of tuners and they all told me get a 2mm gasket or lower compression piston. Even the tech at Full-Race told me to get 2mm HG. I posted about this subject over a month ago and most of the people from this forum told me to stick with stock HG. I'm guessing they're all running lower compression piston. If you have the money then pistons would be better but I think the thicker HG would be fine to lower the compression.
Old Oct 21, 2010 | 08:45 PM
neoleooo's Avatar
Thanks for your advise bro. My injectors are actually Simpsons. Have u heard anything about this brand? What problems did u have with the 650cc RC? What is KBAP?
Old Oct 22, 2010 | 04:19 AM
HMFIC's Avatar
Yikes, 650's on that setup?!
My vote is ID1000's. Tuned well, you're MPG wont change, and it idles and runs like stock. Very very smooth. And your tuner will be happy as well.
Old Oct 22, 2010 | 04:29 AM
s2kdan05ems's Avatar
im running a similar set up just use a stock head gasket, they always blow anyways dont waste your time with it, if you want lower comp just do the pistons and be smart
