View Poll Results: Did your trans blow up? Or maybe it's holding together?
AP1 00-03 Damaged
20.45%
AP2 04/05 Damaged
9.09%
AP2 06+ Damaged
2.27%
AP1 00-03 Running Strong
31.82%
AP2 04/05 Running Strong
20.45%
AP2 06+ Running Strong
15.91%
Multiple Choice Poll. Voters: 44. You may not vote on this poll
Trans failure with high Hp Forced Induction
Old Jul 24, 2013 | 09:37 AM
GrandMasterKhan's Avatar
Default Trans failure with high Hp Forced Induction
We all know that the transmission becomes a weak point on s2000s once you start putting down roughly 500-600whp. But it seems like it may be inconsistent problems and some people are putting down huge power w the stock trans and not having a problem even after many many passes at the Drag Strip. Hell some people have stripped 2nd gear just rolling into the throttle in 2nd w 500whp+.
I understand driving style may be a contributing factor. however the point of this poll to possibly see a correlation between years and which year transmissions show the highest failure rates. For this reason, if you blew up your trans and swapped to a different year and are now running strong no problem. The please vote twice. (example. AP1 guy swapping to an AP2 trans)
There is a difference between 04/05 trans and 06+ transmissions. (Honda has a TSB of improper clearances for some 04/05 transmissions. so I
am curious if we'll see higher failure rates w the 04/05 AP2 trans vs the 06+)
I do not know if Honda changed anything for the AP1 transmissions. if they did I will add the year split to the poll option.
*to be clear. This poll is for damage to the trans because of high whp/tq. Do not include clutch failure or synchro failure due to driver error.
please post the following for reference
-Power level (whp/wtq):
-rear diff (OEM/built/swapped):
-miles boosted:
-s2000 year:
-transmission year:
-clutch:
-CDV (clutch delay valve)
-tires:
-MTF fluid:
-Running Strong / or Explain failure
****EXAMPLE**** My setup: ****
-Power level (511whp/322wtq):
-rear diff (PuddyMod Stg1.5):
-miles boosted: 800 (I hav'nt voted)
-s2000 year: 2006
-transmission year: 2004
-clutch: ACT/OEM Disc
-CDV: REMOVED
-tires: 255/35/18 RE11
-MTF fluid: OEM Honda
-Running Strong (not enough miles boosted to make determination yet)
Old Jul 24, 2013 | 09:48 AM
riceball777's Avatar
-Power level (whp/wtq). 442whp 285tq
-rear diff (OEM/built/swapped) comptech reinforced diff
-miles boosted. 20,000
-your s2000 year. 2002
-your transmission year 2002
No transmission problems. 110,000 miles on stock engine and transmission. 20,000 boosted.
Old Jul 24, 2013 | 09:49 AM
B5254T4's Avatar
-Power level (542whp/wtq):
-rear diff (OEM/built/swapped):OEM
-miles boosted: 2000 miles
-s2000 year: 2003
-transmission year: 2003
-clutch: SOS Twin
-tires: 255/50-16 Mickey Thompson Drag Radials
-MTF fluid: Honda OEM
Blew second gear during a race, girly 542whp. Held up fine for highway but not for MT´s and weekend fun. Low miles on car and tranny.
Old Jul 24, 2013 | 10:10 AM
siadam's Avatar
-Power level (whp/wtq). 700whp 500tq
-rear diff (OEM) upgraded mount stiffeners
-miles boosted ~3500
-your s2000 year. 2005
-your transmission year same / stock
Tranny seems to be extra notchy in second, we will see.
I think clutch type, tires and tranny fluid are also super important.
GM synchromesh fluid.
CM Stage 4 / 4 puck spring
255/45/17 Azenis Rt615
Sent from my iPhone 5 using Tapatalk.
Old Jul 24, 2013 | 10:15 AM
Added
-clutch:
-tires:
-MTF fluid:
Old Jul 24, 2013 | 10:49 AM
passmans2kny's Avatar
-Power level (whp/wtq): 800/6 something
-rear diff (OEM/built/swapped): fbm ford 8.8
-miles boosted: 10,000
-s2000 year: 2004
-transmission year: 2004, now swapped for a v160
-clutch: comp 6 puck sprung at 535hp, comp twin at 800hp
-CDV (clutch delay valve) negative
-tires: nitto nt01s
-MTF fluid: redline
I have to clarify something about my trans failure, it wasnt the case that split, but the section behind that, split it almost completely in half on a 4th gear highway pull, stock trans held for about 700 miles at that power level
Old Jul 24, 2013 | 11:04 AM
cmn's Avatar
cmn
-Power level (whp/wtq):462whp+/468Nm (retuned after 462whp and got more power, but hose blew off aborting the last pull, there not 100% sure on exact #)
-rear diff (OEM/built/swapped): OEM
-miles boosted: ~3500
-s2000 year: 2000
-transmission year: 2000
-clutch: Clutchmasters FX725 twin disc
-CDV (clutch delay valve): No
-tires: Michelin Pilot Sport PS2
-MTF fluid: Oem Honda MTF 3
Old Jul 24, 2013 | 11:07 AM
tx2K's Avatar
-Power level (whp/wtq): Mainline 387/258 Dynojet est 452/300
-miles boosted: 3000
-s2000 year: 2005
-transmission year: 2005
-clutch: CC Stage 4
-CDV (clutch delay valve) yes
-tires: BFG Sport Comp 2
-MTF fluid: Whatever Honda Dealer uses
Old Jul 24, 2013 | 11:20 AM
JoeyBalls's Avatar
--Power 635/453 Dynapack (VSS in 2nd gear)
-- Inline Pro R200 Diff
-- 40,000 miles boosted, about 12,000 at 500+ HP
--2004 AP2
--Clutch CC Stage 4
--CDV Yes, I still have it
--Tires Bridgestone RE070 & M/T Drag Radials
--MTF Amsoil MTF, changed every 6 months
FWIW. When I put the PPG gears in, I will take very detailed pics of my OEM gears/Synchros etc and add them here
Old Jul 24, 2013 | 11:59 AM
Joeyballs, That would be cool to see your internals after all the beating you've given it. Refresh my memory. Did you have a trans failure or just uprgading Just Cause?
