View Poll Results: Did your trans blow up? Or maybe it's holding together?
Multiple Choice Poll. Voters: 44. You may not vote on this poll
Trans failure with high Hp Forced Induction
Old Car
-Power level (whp/wtq): 475whp/320tq
-rear diff (OEM/built/swapped): OEM
-miles boosted: ~2k
-s2000 year: 2005
-transmission year: 2005
-clutch: CC Twin Disc
-CDV (clutch delay valve) YES
-tires: Stock
-MTF fluid: Honda MTF
-Running Strong / or Explain failure Running Strong (until it was totaled by the new owner)
Current Car
-Power level (whp/wtq): 415whp/284tq
-rear diff (OEM/built/swapped): 8.8"
-miles boosted: ~15k and counting
-s2000 year: 2005
-clutch: ACT PP/OEM disc
-CDV (clutch delay valve) NO
-tires: MT ET Streets (26")
-miles boosted: ~2k
-s2000 year: 2005
-tires: Stock
Current Car
-s2000 year: 2005
-Power level (whp/wtq). 700whp 500tq
-rear diff (OEM) upgraded mount stiffeners
-miles boosted ~3500
-your s2000 year. 2005
-your transmission year same / stock
Tranny seems to be extra notchy in second, we will see.
I think clutch type, tires and tranny fluid are also super important.
GM synchromesh fluid.
CM Stage 4 / 4 puck spring
255/45/17 Azenis Rt615
Sent from my iPhone 5 using Tapatalk.
Spoke to soon I guess.
Lost 1st gear, won't go into gear. Rolled into it, tires broke loose (turns out wasn't the tires, lol). Now won't go into gear, while moving, engine on or off.
-Power level: 382/243
-rear diff: OEM
-miles boosted: 4000 miles
-s2000 year: 2005
-clutch: Clutch master FX100
-CDV: Removed in 2007
-tires: 245 NA / 255 boosted Hankook V12
-Explain failure: will not go into 1st or 2nd been notchy since new 2005, past year been increasingly harder to put into 1st or 2nd, last night will not go into second during
a harder acceleration went into a grind like I've never drove a stick before. Trans dead. 2008 trans on order
-rear diff: OEM
-s2000 year: 2005
That sucks!
