Trouble selecting Pistons for Comptech Setup (CR)
Old May 2, 2008 | 10:58 AM
SiCK HONDA's Avatar
Alright, I've decided to go with forged stock compression 11.5:1 pistons and use the Cometic headgasket.
I don't have 3 weeks to wait for custom pistons to be made, and I think 9:1 is too low for my application-- probably better suited to the turbo guys.
Old May 2, 2008 | 05:25 PM
AusS2000's Avatar
Why would you use aftermarket 11.5:1 pistons when you can use the stock OEM pistons (11.1:1, no sleeving)?
Old May 2, 2008 | 05:31 PM
Sideways's Avatar
The factory pistons have inadequate lands for high boost. Slow down and do it right. Sleeve the block, use the 9.5:1 pistons and do it the way you really want it. I noticed very little going from factory 11.0:1 to 9.5:1 other than it starts easier due to less compression.
Old May 2, 2008 | 05:33 PM
AusS2000's Avatar
Do you consider 12psi (SC peak) to be high boost?
Old May 3, 2008 | 08:21 AM
SiCK HONDA's Avatar
I HAD to sleeve my block because of the damage to the cylinders.
Does that change anything?
I can't find any pistons readily available that aren't either 11.5:1 or 9:1.
This is currently my only car... I mean I "could" go out and buy another car, but I just don't want to right now.
I can't afford another 3 week wait for custom pistons, as I've been without a car for 3 weeks already.
My options are limited to 9:1 with stock headgasket or 11.5:1 with cometic (dropping it to 9.8:1)...
The block is being sleeved either way.
EDIT: I'M AN IDIOT... I didn't realize that 11.5 is not the stock compression ratio... So now, I'm even more confused...
I guess running 11.5:1 pistons with a cometic headgasket is out of the question?
Old May 3, 2008 | 08:44 AM
SiCK HONDA's Avatar
Were you able to find 9.5:1 pistons or did you have them made?
Do you think that say a JE or CP 9:1 piston is too low for my setup (Maxing out at 12psi)?
Thanks,
Matt
Old May 3, 2008 | 09:18 AM
ERL_S2000's Avatar
Matt slow down man.DO NOT buy a 11.5:1 Piston. That is .5 higher than the stock compression, you are going the wrong way man. You need to get a 9.0:1- 9.5:1 . Im sorry your car has been down buy its just part of the game. Do not half ass something because you are stressed on time. If you are still using a 87mm sleeve, and you are short on time, go back to the stock piston and put the car back together. If you want to do it right, go with a Low compression piston. The wait time on some 87mm 9:0 wiseco pistons is not that long.
Old May 3, 2008 | 12:39 PM
ATOice's Avatar
Go with higher boost..not 12 psi if you can. If you want to do all this work and investment, do it how you want to do it. I just don't think 12 psi, and you want more later can cost you more going with pistons.
Old May 3, 2008 | 02:37 PM
S2SEXY's Avatar
atoice are you 10psi on stock compression?whats your setup?
Old May 4, 2008 | 09:54 AM
SiCK HONDA's Avatar
I am in the process of getting 9:1 pistons... I will run the stock headgasket.
I messed up and ordered the 11.5's without realizing that they aren't stock compression.
I really don't want to run much more than 12psi... My goal is to have a fast daily driveable car.
Thanks for all you guys' help... It is greatly appreciated.
-Matt
