Trouble starting car when hot.
Old Jul 12, 2007 | 08:22 AM
  #21
fadiss2k's Avatar
Have the same problem!!! subcribing!
Old Jul 12, 2007 | 08:15 PM
  #22
flexmyrex's Avatar
Originally Posted by ChefJ,Jul 8 2007, 08:16 PM
My car will fire right up when its dead cold. When it has been running for awhile it is drawing so much amoerage that it has blown the 150amp fuse that was installed next to the battery and now I am running straight metal bar in its place just to crank it over. I have to hold the throttle wide open and hope it fires up. It cranks sloly and is just drawing so much power the lights dim does anyone have any idea what could be causing this. It just started happening within the last week.
A bad battery is not going to blow the main fuse nor will a main relay, you have a short to ground in the starting system. Check the + cable from battery all the way to the starter solenoid B+ terminal. If the cable looks good you have a short in the starter solenoid/motor windings. When ambient temps increase the resistance in the starter windings increase as a result it draws more current.
Old Jul 13, 2007 | 08:14 AM
  #23
snakeeater's Avatar
You have a short it you are blowing a 150 amp fuse. The short may only show up once you get warm though. I hope you have very large cables from the battery, especially since they are no longer protected by a fuse . Find the short and fix it, this is a fire waiting to happen.
Old Jul 13, 2007 | 07:48 PM
  #24
ChefJ's Avatar
Weel I drove home tonight and then went out to go for a drive and I had to hold the pedal down for it to start. Doesn't this mean that its getting to much gas and you need to hold the throttle open to get some oxygen in there to combust?? What could be causing this am I running to rich and flooding it out?
Old Jul 13, 2007 | 07:51 PM
  #25
The Dude Abides's Avatar
Mine does this too, I thought it was an AEM FMU issue. Many others using it have had the same issue too
Old Jul 14, 2007 | 07:51 AM
  #26
Spec_Ops2087's Avatar
I use a synchronic FPR and have 0 problems with ANY kind of starting.
Old Jul 19, 2007 | 09:28 PM
  #27
fadiss2k's Avatar
any updates on this?
Old Jul 19, 2007 | 10:34 PM
  #28
AirborneS2K's Avatar
stock fpr, and mine takes a while to start up when hot too...
Old Jul 21, 2007 | 10:49 PM
  #29
fadiss2k's Avatar
so, its the stock FPR???
Old Jul 22, 2007 | 01:33 AM
  #30
doubt it, I'm running 675 cc injectors and IP's tuner tuned my car...so it's a damn good tune.
