Trying to decide on Gear ratio 3.9 or 4.10?
Old Mar 20, 2012 | 05:04 AM
sohc_mshue's Avatar
Default Trying to decide on Gear ratio 3.9 or 4.10?
Hey guys I am about to switch over to a Ford 8.8" and am having trouble deciding if I want a 3.9 or 4.10 ring and pinion ratio. Who on here has tried the 3.9 and how much power are you making? Did it improve times? I am afraid that if I go with the 3.9 with my current power level (515whp) It will kill my acceleration...although it would keep me from having to shift to 5th gear. I plan to up the power later on down the road.
Old Mar 20, 2012 | 05:58 AM
passmans2kny's Avatar
i would go with the 3.9, with all that power you want longer gears, also it will help with traction
Old Mar 20, 2012 | 06:02 AM
spectacle's Avatar
Makes for a more settled street car and should allow you to pass the traps in 4th.
Old Mar 20, 2012 | 06:23 AM
TerminatioN's Avatar
Definitely 3.9
Old Mar 20, 2012 | 06:44 AM
sohc_mshue's Avatar
Good i think i'll give the 3.9 a try then. Looks like Richmond Gears is one of the only companies that makes it? Any places have a good deal on them?
Old Mar 20, 2012 | 07:21 AM
i got my richmond 3.9 off jegs, they have em for 165$
Old Mar 20, 2012 | 08:38 AM
theprophet36's Avatar
I've got 3.9 and not nearly that power level. Couldn't be happier
Old Mar 20, 2012 | 06:08 PM
sohc_mshue's Avatar
Parts ordered!
Old Mar 21, 2012 | 04:12 AM
JoeyBalls's Avatar
3.9, Shifting into 5th in the 1/4 blows
Old Mar 22, 2012 | 03:44 AM
sohc_mshue's Avatar
Originally Posted by RealStreet
Personally I would go 4.10. Big reason is so you can get Ford Racing 4.10 gear which is OEM quality. The aftermarket 3.90 gears are noisy. If you have a AP1 and springs/retainers then I would do the same thing I did when I was at that power level. 26" tire and 9500rpm or so. You will cross in 4th.
Yea the 4.10 with 26" is perfect for my power level now, but once I go to higher power even at 9500 rpm I will need to shift at 133mph. I guess this will be more incentive to up the power!
