TTS Race Kit - 546BHP
Originally Posted by soulicious
He must have had belt slip or some other issue. I know a stock SOS 3.0" pulley slips like a mofo. I had to seek an alternative pulley. My 1200 SOS S/C makes 492/319 on a DynoJet with stock exhaust.
Originally Posted by leoxle
Only 264kW with the SOS stage 2 on a 3.2" pulley with e85? That sounds a bit low, were you using a novi 1220 or 1200? Just curious because I have a so stage 2 as well lol. However, great results on the TTS!
If im not mistaken, “ILovemyHonda” made dynojet 585whp/360trq on a 1200 running E85.
May have been,but I thought it was higher then that on the 1200. He made over 600 with the 1500. Was like 620 something. The 1500 at its peak only puts out 50 cfm more then the 1200 blower fyi, so around 580whp/1200 would coincide with that.
Originally Posted by s2000Junky
13psi isnt close to maxing out that blower. Sounds like you had issues for sure. I think if you were running the same boost on the 1200 as you are the TTS kit, you would see every bit of what your currently making. Not taking anything away from TTS, their kit delivers, just find your situation a bit unorthodox. Running the proper size belt and tension, I don’t have any problem spinning a 3.2” pulley making 16+ psi on the 1200. If im not mistaken, “ILovemyHonda” made dynojet 585whp/360trq on a 1200 running E85.
I do however recall reading somewhere the struggle of some to hit over the 450whp mark with the SOS stg 2 kit. My belt wasn't slipping and we only saw 13psi so I decided to try something new which got me there in the end so no harm done
