Tune Finished
Originally Posted by DrBelmore,Jan 24 2007, 01:22 PM
Do you guys think the power he got could be higher because of the gear that they did the pull on? In the one video it looks like they did it in 4th gear and then in the other video (unless he started recording late) looks like it was 3rd gear. Just a thought.
It wouldn't make that much difference.
Originally Posted by Scorpion,Jan 24 2007, 01:05 PM
I agree that there is no way 550cc injectors will make that power. You would be way lean. And that's math, you can't argue it.
The fuel math does not work.
I did not see an aftermarket FPR in his mod list, so at stock fuel pressure there is no way to make that much power.
Even with an aftermarket adjustable FPR and cranking up the pressure you cannot make it work, even driving the 550's to 95% duty.
Go here:
http://www.rceng.com/technical.htm#WORKSHEET
And calculate it for yourself. In addition, do not forget to calculate the crank horsepower when you do figuring 15-17% driveline loss.
Originally Posted by Ray K.,Jan 24 2007, 02:24 PM
people are getting very bent out of shape over this. Nobody has questioned the dyno operator or dyno calibration yet? I would look there first.
You're right. I should just drive up there (not too far away) and dyno my car.
I would pull 455whp with my current setup on pump gas and call it a day.
Originally Posted by geists2k,Jan 24 2007, 02:53 PM
Nobody is bent out of shape?
You're right. I should just drive up there (no too far away) and dyno my car.
I would pull 455whp will my current setup on pump gas and call it a day.
I want a graph that says I'm putting down 455 whp on 9.75 psi too.
