Tuned today inlinepro
Old May 30, 2007 | 05:04 AM
PRS2K's Avatar
Here is your "identical" setup at 9psi minus the Head Gasket
Old May 30, 2007 | 05:37 AM
revhi's Avatar
What does the 3mm gasket drop the compression down to?
Old May 30, 2007 | 06:07 AM
blackout's Avatar
I would try to get a little more fuel in there at the top end, that could be dangerous granted its Stoich but definitely upping pressures and heat, I would run it a little rich. Sounds like the oil could be losing you some power too
Old May 30, 2007 | 07:40 AM
Dsgs2k3's Avatar
with a 3mm headgasket you will lose anywhere from 35-50hp. also tell your tuner to richen it up a bit like around 11.7. and then all is left is to up the boost to make up for the gasket
Old May 30, 2007 | 11:14 AM
afwfjustin's Avatar
I think it's a combination of your stock clutch and the gasket. Those numbers do seem a bit low, and your AFR is a bit dangerous at WOT. Mine is in the mid 12's and even that is high, hence me needing a retune also
The Inline kit is more of a street kit, and is going to show more conservative numbers. Still, I thought you'd hit 320-330 on 10psi.
I think with a stronger clutch you'd see some nicer numbers, and some fine tuning. The gasket is there for you to boost higher so, it's time to up the boost
Old May 30, 2007 | 11:42 AM
AirborneS2K's Avatar
9:1
btw chef I give you permission to 'transport' my car to the dyno from wherever it currently sits ; )
Old May 30, 2007 | 11:52 AM
AROD's Avatar
i'd like to hear your thoughts on why inline pro is a street kit............
Old May 30, 2007 | 12:43 PM
CIVICTOS2000's Avatar
Old May 30, 2007 | 12:50 PM
OGPackin's Avatar
What make InlinePro's kit a "street kit" ?
Old May 30, 2007 | 12:52 PM
OGPackin's Avatar
ps....my first dyno run #s were 313rwhp @ 9psi boost
