Tuning
Old Jun 4, 2005 | 01:15 PM
JAYZS2000's Avatar
Default Tuning
I have a Comptech supercharged MY 03 with a test pipe. When I put the test pipe on my car obviously tripped the check engine light. I bought a O2 simulator to take care of that problem, but haven't installed it yet. It seems that my car is running rich so I bought a VAFC 1 to try to lean it out some. I haven't installed that yet. The problem I have is can I install all of these components along with the piggy-back that hooks to the ECU from Comptech and it work? If i can this seems to be a tuning nightmare and I can't find anyone with a dyno or knowledge to tune it for me around NE Ohio. Any recommendations would be appreciated.
Thanks
J
Old Jun 4, 2005 | 01:29 PM
xviper's Avatar
How have you made this determination and what kinds of a/f numbers are you getting?
You mean to say you have NOT installed the Comptech ESM yet? If not, why not? The kit needs this to work properly. You may be getting more than just the code for the test pipe. You may also be getting a code for the MAP sensor seeing boost.
ps. We have a F.I. forum. Moving this there.
Old Jun 5, 2005 | 08:53 AM
my01s2k's Avatar
Am currently running a stock comptech supercharged with after cooler. Am also new to the supercharge scene. My question is, if I want to upgrade to the 7lbs pulley, can I tuned the car (professionally done of course) AS IS, without having the VFAC or the AEM EMS? Or I must have one of them to tuned with?
Old Jun 5, 2005 | 07:08 PM
my01s2k's Avatar
^ anyone???
Old Jun 5, 2005 | 07:31 PM
xviper's Avatar
Yes, I've witnessed this myself at the Comptech factory with a friend's car. They put on a higher boost pulley, checked it on a dyno, turned up the fuel pressure a bit to get the a/f into a safer operating zone, went home. This netted 20WHP.
Old Jun 5, 2005 | 08:35 PM
AusS2000's Avatar
It might be safe, but it's not tuned. Without some aftermarket tuning device your entire tuning method is to twist the screw on the FPR. You have a bit more control with a V-AFC but it's still a bit of a fudge.
Anything more than the stock Comptech pulley and I would want at least an E-manage.
Old Jun 5, 2005 | 09:43 PM
Silver S2k4's Avatar
the VAFC will definetly do the job with only 7 psi. You can't really do much tunning with the FPR so that is worthless. Put the VAFC on and the 02 simulator and go to someone with a dyno and a wideband 02 sensor.
Old Jun 6, 2005 | 06:45 PM
JAYZS2000's Avatar
I have installed the ecu from Comptech and it ran fine until I put the test pipe on. Thats when I noticed it smelling of gas.
J
Old Jun 6, 2005 | 06:48 PM
JAYZS2000's Avatar
I meant ESM not ecu
Old Jun 6, 2005 | 06:49 PM
well ofcoarse you will smell gas, you'll shoot flames too.
