Tuning on E85?
Old May 16, 2007 | 09:04 PM
squirrels2k's Avatar
the evo and sti guys that i've met in cheyenne and denver swear by it. my tuner even says it's pretty good if you wanna up the boost and make a bit more power. most of the cars he tunes, he makes an extra map on e-85 for them just in case. personally i don't want to put that corn pone shit in my car but... in the end who knows. where you located at ?
Old May 16, 2007 | 09:38 PM
SPECIAL-OPS-S2K's Avatar
lol yeah they sell it all over in lincoln, ne where i live... forget the E85 get meth injection running 50/50 and crank the boost... then you dont need two maps and can run on the 91-93 octane that is anywhere
Old May 17, 2007 | 10:44 AM
cock_diesel's Avatar
Im located in duluth minnesota. We have the e85 all around the twin cities and I have 3 pumps to choose from here in duluth
Old May 17, 2007 | 12:06 PM
pushin9's Avatar
Originally Posted by AP1_S2k,May 14 2007, 10:47 PM
That must be a midwest thing, I have a local pump that sell 110 octane but no corn fuel
I am from WI and E85 can be found just about anywhere
Old May 18, 2007 | 09:08 AM
[QUOTE=pushin9,May 17 2007, 12:06 PM] I am from WI and E85 can be found just about anywhere
Old May 18, 2007 | 10:48 AM
pushin9's Avatar
Originally Posted by cock_diesel,May 18 2007, 12:08 PM
Do you run your S on e85???
nope
Old Jun 24, 2007 | 11:23 PM
s2guru's Avatar
anyone running this e85...??
my tunner is telling me i can run more boost with E85. with more HP gain... but whats the consequence of running with this gas?
what need to be upgrade to run this? supporting mods?
Old Jun 25, 2007 | 03:28 AM
Venomous S's Avatar
Since it contains alcohol and alcohol is corrosive, your fuel lines would corrode I would think, unless your system is flushed out periodically.
I think the 2 requirements to run this fuel is to have a stainless steel fuel tank which should be/is standard on all cars and the use of Teflon lined fuel hoses
Old Jun 25, 2007 | 05:30 AM
Kwando's Avatar
s2guru - Jeremy in the springs has tuned multiple cars with E85. you might want to get a hold of him.
Old Jun 25, 2007 | 08:29 AM
bruthaboost's Avatar
Alcohols also have a tendency to pull water though for the purposes of combustion the amounts are probably negligible (in chemistry reactions they are not). However I am curious about long term storage (e.g. pump stations) and and the QC/QA of E85.
Have a friend that had a suby that ran E85. Had two separate tunes and loved the corn stuff. Said E85 made his car feel like it was running on a dry, bright cold winter day when it was really the middle of summer with blistering heat and oppressive humidity. Ran more boost and with no detonation. He was data logging as well.
If we had more stations here, I'd run it. We'd have to run a larger injector. I forget the calculation off the top of my head. Would kind of rule out using the aem piggy back though since you can't remap closed loop (unless you fooled the piggy back with the size injector you're using to compensate I think)
