Tuning on E85?
Old Jun 25, 2007 | 03:48 PM
  #21
cock_diesel's Avatar
[QUOTE=s2guru,Jun 24 2007, 11:23 PM] anyone running this e85...??
my tunner is telling me
Old Jun 25, 2007 | 03:55 PM
  #22
pushin9's Avatar
Originally Posted by cock_diesel,Jun 25 2007, 06:48 PM
Im tuned by Jordan @ consummate tuning on AEM EMS
do you have a dyno graph you could share with us?
Old Jun 25, 2007 | 04:15 PM
  #23
I have not dyno'd yet... Hoping to july 14th so when I do ill post it up for everybody
Old Jun 26, 2007 | 10:30 AM
  #24
blackout's Avatar
there are pros and cons to all types of fuel
alcohol - runs cooler, cleaner more power, higher octane, so more boost is an option.
but alcohol has a much richer stoich ratio so your milage is declined. It also has no lubricating properties that petro does.
Old Jun 26, 2007 | 10:38 AM
  #25
s2guru's Avatar
Originally Posted by cock_diesel,Jun 25 2007, 05:48 PM
I currently have over 4000miles on my e85 turbo setup, It runs mint!
No corrosion problems at all, and for "converting over for it" I have 1600cc injectors and a walbro 255 fuel pump. I am maxing out the fuel pump around 17-18psi so im upgrading to an external aeromotive 1000 or dual 1000's.
so if i go E85 i have to upgrade the fuel pump? i have the walbro 225. with rc 1000 injectors.
on regular 91 oc, how much can the walbro 225 fuel pump take ( PSI) ???
Old Jun 26, 2007 | 06:13 PM
  #26
flexmyrex's Avatar
it all depends on your power goals, fuel pressure, and how safe the tuner feels about injector duty cycle. Personally with gasoline i have maxed out the walbro 225 HP pump @ 65psi- precision 1000cc 580whp (dynojet) on a 2.0 4 cylinder honda motor. Anything after that power level the pump could not flow enough fuel to hold the given pressure and pressure would drop after 5,5k which would lean out the mixture.
With ethanol it takes about 20-30% more volume to get same hp. The 225HP via a relay with higher current supply to pump it should not have any problems flowing more than enough to make 500-520+whp with steady supply of fuel pressure all the way to redline. You can always push more ponies by increasing injector duration when fuel pressure drops but it is not the way to do it
Old Jun 26, 2007 | 06:28 PM
  #27
fperra's Avatar
I have Precision 1000cc injectors and that is exactly what happened to mine with the Walbro pump.
Old Jun 26, 2007 | 09:19 PM
  #28
s2guru's Avatar
so i should be good for now, with this fresh block from laskey racing, i should be making 520whp
Some87
Aug 18, 2016 02:31 AM
ryanvo
Jun 14, 2013 03:51 PM
Excalibur
Sep 24, 2012 02:14 PM
RedLineS2k10
Oct 17, 2010 05:47 AM
Shftat9k
Nov 19, 2009 09:17 AM
