Turbo Build
yah, thanks for the tip. I will most likely be getting it welded, I am SOL(shit out of luck) to turboing her until I get an inspection sticker! I am so close but yet so far. P.S I live in Mass.
Jordan
Jordan
I welded my own intercooler plumbing, any reputable machine/welding/performance shop should be able to do it for you. Being a certified welder, I would recommend only tig welding the aluminum intercooler plumbing. It should be a snap if you are using a quality 6061 aluminum, prep the surfaces, and use a quality 6061 filler. I wouldn't trust brazed aluminum joints for holding pressure. Make sure the welds get some good penetration and are not undercut. Should look somewhat similar to this:
Originally Posted by 2big4aS2000,Jun 26 2008, 08:10 AM
if you know what your are doing a clutch is not problem - 2 1/2 hours start to finish
Took me a week!
Ok, so a sunday followed by a saturday with some driveshaft bolts procured during the week.
And I was working alone with the car on jack stands so I'm pretty happy with it but not keen to do it again.
