turbo built f20 motor
Old Jul 9, 2010 | 04:52 PM
bois2k's Avatar
Default turbo built f20 motor
Hey guys im building my motor because had a huge scratch on my cylinder wall so far we put the darton sleeves in was wondering what size pistons would b best and any other things i should do to it?
Old Jul 10, 2010 | 07:10 AM
ap1tuner's Avatar
well with my turbo build, i went a less traveled route. i built my bottom end but kept the 11.0:1 compression and bored the cylinders out .5 over. i used cp pistons and steele sleeves, acl race bearings, arp head studs, and a factory honda head gasket. the head was fully built with BRIAN CROWER dual core valve springs, titanium retainers, swirl polished valves, and im taing out my n/a bc cams and putting my stock ap1 cams back in.
Old Jul 10, 2010 | 09:47 AM
bois2k's Avatar
Oh very nice i was thinking cp pistons, acl bearings with a cometic head gasket but i was wanting to lower the compression was really wanting to boost a safe 14psi but i dont know to much sao need some advice
Old Jul 10, 2010 | 08:10 PM
m R g S r's Avatar
so you installed darton sleeves and you nor the builder know what to do with the motor now? i dont get that lol
Old Jul 10, 2010 | 10:03 PM
ap1tuner's Avatar
well if you got the engine cracked open right now, if your wanting to boost high psi safely, go with low compression pistons and a good stock thickness head gasket (IMO) bc i hear alot about these thicker headgaskets causing issues. if you wanna go my route (higher compression, lower psi) get something like cp pistons and some good rods and such and get it tuned REALLY well. higher compression engines are more finicky with boost, but can make power quick off of a smaller amount. just something to think about.
Old Jul 10, 2010 | 11:07 PM
S2000_FUN's Avatar
I would go with lower compression than 11.0:1 and a good set of aftermarket parts that was mentioned before because soon you will discover that 14psi is not enough . People who tend to improve their motors want to go higher all time. So you better do something on the safe side from start to have the room to play with boost if you need too
Old Jul 11, 2010 | 08:33 AM
ap1tuner's Avatar
^^ no love for the high compression builds?
Old Jul 11, 2010 | 12:05 PM
bois2k's Avatar
Sorry i just had the mechanic install the darton sleeves.. and was gona order the cp low compression pistons acl bearings, rods and not sure how big on the headgasket.
Old Jul 11, 2010 | 06:35 PM
AusS2000's Avatar
How big on headgasket?
Decompress with the pistons so normal thickness. And diameter is decided by the size pistons.
Old Jul 11, 2010 | 06:52 PM
bois2k's Avatar
OK then so normal size head gasket its is thanks think ima go 88mm
