Turbo Cams
Its not that they are "all motor" cams. It's giving the engine the duration/lift that it needs. Ive helped do some very wild stuff on a lot of FWD turbo cars, and help break records. I know that is a "B" engine, but a 4 stroke engine, is a 4 stroke engine. Only difference between the two is the follower. One is a roller and other a radius, and that is where a lot of people have problems. The roller follower you loose a good 20 degrees in the engine compared to checking the cam on a cam doctor with a flat follower. Just give me another 2 weeks tops and I will have some very good info for everyone on here.
One more thing for the all motor cam thing. There are changes between a 900hp engine and a 300hp N/A engine. Its changes that are more in debt then just the "duration @ .050" and lift. Well at least at Web...
There is actually a lot of power to be had in the camshafts over stock. Just not in the "off the shelf" ones.
I'm running a set of custom Jeremy Allen cams, and they are crazy good from what we saw on the engine dyno.
Contact Inline Pro if you are interested in a set. Good stuff!!!
I run a BC stage 3 exhaust cam and ap1 intake cam on a Frankenstein 2.4
Just had engine rebuilt and cams weren't causing any problems.
Don't have a back to back comparison for you but I havent had problems with it.
We're testing the BC stage 2 cams on my engine coming week. It's being fully mapped at the moment on stock AP1 cams so we'll have a back to back comparison.
Rest of the setup is AP1 stroked to 2.2, GT35R turbo, InlinePro intake manifold. I'll update.
I will most def keep everyone updated! I just finished machining the cam yesterday, so now install tme!
