Turbo choice
Old Oct 5, 2008 | 08:18 AM
S2KB00ST's Avatar
Default Turbo choice
I'm looking for around 420-450whp for now on bone stock block to keep me happy for now. Maybe build the block later when it blows. I want a fast spool and good midrange. Curently I have a GT35R 0.63 ar turbine. I'm thinking if the 3076R 0.82 would suit my setup better. Shall I swap the GT35R?
Old Oct 5, 2008 | 09:00 AM
AndyFloyd's Avatar
I agree, i am using the 3076R .82 and it will spool in the 4000-4500 range. The 35R will spool in the 5000-5500 range. The 35R will be a better topend turbo but the 30R will have a large midrange advantage for sure.
Old Oct 5, 2008 | 09:47 AM
timg's Avatar
Even the GT3071R would come close to those numbers. I do like the GT3076R with a 0.82 a/r turbine housing though. It all depends on how much lag you are willing to accept and how efficient your setup is.
Tim
Old Oct 5, 2008 | 10:32 AM
S2KB00ST's Avatar
As I would not need to be running too much boost on the 35R to get to 430whp+ for now I figured that it might be a little 'oversized' for what I need right now... I also don't want to have to deal with boost creep that may occur, at least with the 3076 I won't have to bleed off so much boost..
Tim, at what rpm are you fully spooled by and at what psi?
Old Oct 6, 2008 | 04:17 PM
passmans2kny's Avatar
gt30 with .82 all the way
Old Oct 6, 2008 | 05:25 PM
ERL_S2000's Avatar
I too am waiting to finish my setup. I have a GT3076R .82AR as well. I opted to go with this because I wanted the midrange power and with my setup should be able to support 500whp. If you really want a very responsive turbo you could do the GT3071R... I think with either you will be happy.
Old Oct 6, 2008 | 05:46 PM
timg's Avatar
Full boost by 4k rpm (I think this was something like 7 psi) Note that higher levels of boost arrive later (I think 16 psi was around 4500 rpm) and boost also hits later in lower gears.
Tim
AZ-S2000
May 1, 2012 01:04 AM
fit4897
Apr 15, 2007 08:19 PM
nrgetik
Sep 13, 2006 10:40 PM
Polimangas
Sep 11, 2006 10:44 PM
Project S2000
Oct 4, 2004 12:04 PM
