Turbo coolant lines
Originally Posted by s2guru,Jul 24 2009, 08:40 PM
dsddcd: thanks for the pic. what size is that hose -6?
you don't think the An fitting will burn the inside of the hose after it get hot?
I like your newest design, but I also think if you use the correct parts it will work just fine. Using highend fittings such as Aeroquips steel and stainless with thier heavy duty line you might have better luck.
I will update Thursday with the results, i'm using the same fitting for both sides feeding/draining.
you guy should see the old ss hose, it was toasted inside. No wonder it was leaking =/
That's a huge problem with the SS hoses. The outside heats up and the inside melts. From the outside they look fine, but they're leaking like crazy. Coolant leaks to my turbo actually cost me my stock motor...
Tim
Tim
Tim
Tim
I've seen people heatwrap the lines, but is there a cleaner way of going about this?
