turbo f20c miata
Old Nov 2, 2010 | 07:13 PM
hingstonwm's Avatar
Default turbo f20c miata
Not sure if anyone here would be interested is this or not, but figured I would post it anyway.
I would like to thank pang, without his help, this project would still be just an idea.
[media]http://www.youtube.com/watch?v=Fem2Pdwun6s [/media]
Old Nov 2, 2010 | 07:45 PM
CaseyGW's Avatar
very cool. more info on the setup?
Old Nov 2, 2010 | 07:49 PM
jaundice's Avatar
This is similar to fyrestrikes Miata that he did. Very cool build.
Old Nov 2, 2010 | 08:26 PM
buzz944's Avatar
impressive
Old Nov 2, 2010 | 09:34 PM
Alloy Craft's Avatar
Former Sponsor
Nice, Its still a chick car though,------ I kid, I kid.
Old Nov 2, 2010 | 10:59 PM
hingstonwm's Avatar
2003 AP1 with 16,000 on the clock, AP2 tranny
stock head gasket
Pfab ELT manifold
Garrett 3582 turbo
Tial 44 WG
Tial 50 BOV
3" down pipe with recirc dump tube
3" exhaust
Manifold, down pipe, turbine housing coated with swain coat white lightning
ID 1000 injectors
inline pro fuel rail
bosch 044 fuel pump (gravity fed from bottom of tank outlet)
weldon rising rate fuel regulator 62# base pressure
-8 supply line
-6 return line
2.5"hot side 2.75 inch cool side charge pipes
pfab custom IC
hondata 4 bar map sensor
cc stage 4, sprung 6 puck
AEM version 1
AEM UEGO
tuned on E-85
12 # boost
Old Nov 3, 2010 | 12:39 AM
ScorpioMk's Avatar
Looks awesome! I'd be interested in seeing pics of the crossmember and mounts and how you went about that.
Old Nov 3, 2010 | 08:00 PM
teamvalorracing's Avatar
no curve in the graph huh? looks like a damn roots f20 or a SC 370Z graph! lol
cool build!
Old Nov 3, 2010 | 10:09 PM
hingstonwm's Avatar
If you look on the sides of the engine you can see the motor mounts
Engine mounts were pretty straight forward to fabricate. I had the engine and transmission located in the car where I wanted them. The engine was sitting on wood spacers located on top of the skid plate and also supported by a hoist. plates were fabricated and bolted to the engine. Then the rubber engine mounts were bolted to the sub frame, and a plates bolted to them. After this was done, I used a file folder and cut template that fit between the plate on the engine and the plate on the engine mount. All that was needed at this point was to transfer the pattern to plate steel cut out the pieces, tack them into place and weld them up.
Here are a few sots of the thermal ceramic coating
[B]
Old Nov 3, 2010 | 10:14 PM
hingstonwm's Avatar
cool build!
The curve is very linear, very easy to drive. 1st and 2nd are worthless at wot, but that's okay it gives me something to work on..
