Turbo hittting the frame
Old Sep 30, 2007 | 06:57 PM
REVHIR's Avatar
Default Turbo hittting the frame
Right now my turbo from inline pro is sitting on the frame. It is not the whole thing of course because they notched it already.(a square hole) The coupler is still resting a bit on the frame thought because that is the only part that was not cut because of saftey reasons. IS there something that anyone out here can SHOW me and tell me how they did it. Ideas are welcomed very much thanks. Oh and by the way i need to polish the hell out of my charge pipes where can i get that done too? and how much does it run?? thanks guys....
This is what i have already.... and at idle it vibrates the frame. The red part i circled is resting with the coupler part of the turbo.
Old Sep 30, 2007 | 08:59 PM
Hasid Lafre's Avatar
Well if you do notch it make sure you corners are rounded off.
A sharp corner will add a failure point and possably bend the frame.
Being a old minitrucker its best that what you take out you put back in to get some support back.
Old Sep 30, 2007 | 09:07 PM
SPECIAL-OPS-S2K's Avatar
Goin InlinePRO in around December... VERY INTERESTED in seeing EXACTLY how to notch the frame... subscribing.
Old Sep 30, 2007 | 09:08 PM
REVHIR's Avatar
how would i go about doing it though?
Old Sep 30, 2007 | 09:47 PM
Well use something that will cut the metal like a grinder or something then when you cut it out make sure your edges are rounded off. No sharp corners.
Old Sep 30, 2007 | 10:14 PM
REVHIR's Avatar
round edges?? hmmm to absorb a hit? Can someone elaborate on this?
Old Oct 1, 2007 | 12:59 AM
*puts on minitrucker hat*
Ok if you round off the edges of a notch it wont be as much of a weak point. If theres sharp edges and corners it will ultimatly lead to a failure point. 1: it could cause a crack that could spread thru the whole of the frame.
2: if it does crack wherever is forward of it could brake off by its own weight.
There was an epasode of trucks! on spike tv called project body bag, They talk about frame notching and such and inform you about how important it is to have rounded edges and no sharp corners.
I have seen many horror storys cause someone dident do there front spring pocket right. they were riding down the hiway casually then all of a sudden the front passanger side hits the pavment. Spring pocket ripted itself off the frame.
It just lessons the likleyhood of a crack in the frame and spreading like a spiderweb.
Old Oct 1, 2007 | 07:42 AM
chairmnofthboard's Avatar
It's on a seam, a weak point.
Unlikely anything will happen, but I personally wouldn't cut it.
So all inlinepro kits need to cut into the frame? that's crappy.
Old Oct 1, 2007 | 07:55 AM
slimjim8201's Avatar
Incorrect. Many turbo housings are small enough to fit. I'm not a huge fan of notching the frame, but there are enough guys running this way to convince me it's safe.
Old Oct 1, 2007 | 08:02 AM
Im going to run the InlinePRO w/ a gt3076R .82 a/r I'm pretty sure I will need to notch it... anyone got pics? details of the best way / place to cut?
