Turbo kit help
Old Aug 23, 2007 | 11:16 AM
SecondRound's Avatar
Default Turbo kit help
Ok, i got a situation. I want to put a power adder on my car. However, should I turbo the car, supercharge the car or do cams? I am in the pittsburgh pa area and i dont know many honda tuners but there are some shops here that dyno tune. What would be the best thing for me to do to the car in your mind and what kits would you recommend for each different power adder? thanks alot!
Old Aug 23, 2007 | 02:36 PM
SPECIAL-OPS-S2K's Avatar
Not gonna start a debate over whats the best of each means of adding power but I'll give you an idea...
Turbo-
This will give you the most power for the money... but be ready to spend between $3k-$11k (yes the range is that big... thats the difference between doing it cheap and doing it right) There are lots of kits outhere and everyone has a preference... I have researched it alot and have determined that the Full Race and InlinePRO kits seem the most complete and highest quality... Full Race is more and will be a less reliable and more quirky / modded seeming car as it is a tubular manifold design that spools more effeciently but also causes heat issues, is prone to cracking, and is not a COMPLETE kit... InlinePRO however is slightly cheaper and will be slightly less efficient but will drive more like a factory turbo car and be more reliable... they use a cast iron manifold design so heat is WAY less of an issue... that should get you started
Supercharger-
I haven't REALLY looked deep in to going SC but I know there are two main brands one is comptech and I cant think of the other off hand... if you are interested in going SC, PM "Sideways" as he is I believe the highest HP SC S2K on the board... I'm not sure about the cost but I think its in the $3k-$5k range...
Cams-
Forget it. There are no cams out there that are PROVEN to make significant power, Honda spent millions making sure they wrung EVERY HP they could out of this engine in its NA form... staying NA will by far be the MOST EXPENSIVE when considering cost per HP gained... although inlinePRO makes a 2.5L stroker that is pretty sick!
Hope this helps!
Old Aug 23, 2007 | 07:26 PM
i will look into that comptech or stroker kit! thanks man i appreciate it very much
Old Aug 24, 2007 | 05:17 AM
passmans2kny's Avatar
i say go turbo, if your in pa go to evans tuning
Old Aug 25, 2007 | 07:40 AM
i have heard some good things about that place. Alot of my buddys with turbo civics and integras go there. is it reliable tho?
Old Aug 25, 2007 | 06:25 PM
PAYELS2K's Avatar
keep your car n/a you dork.
Old Aug 25, 2007 | 10:55 PM
woo's Avatar
woo
Go turbo, n/a ain't worth it unless you have lots of money to spend on your car.
RXM9600
Jan 23, 2014 09:06 AM
ap1ap2whocares
Oct 21, 2012 12:01 PM
donaldmejr
Mar 24, 2012 09:38 PM
S2K_2003
Feb 27, 2010 05:42 PM
Liemoanh
Socal Swap Meet
Oct 23, 2005 10:42 PM
