Turbo Kit for my RHD
First Question i have is where can i find a Turbo Kit for my RHD (please no no Name charger) ?
And wich size of Turbo will be Good for a First 350+ Hp Goal .
later ich will Strocker the Engine and go p to about 450 Hp.
I have 980 injectors here from my Drift Skyline can i use 4 of them in the s or to Big?
Thanks a Lot
Thanks a Lot
Should post this in the forced induction forums. Full blown makes a rhd manifold. I use 1000cc injectors . you can hit 450whp without a stroker . Im at 475 on stock block. Do some research and be ready to spend around 10,000$ to have a solid setup.
Sent from my Galaxy S II using Tapatalk
Thanks a lot! There are also no kits avible?
I want the Turbo on the exhaust side! Not in front of
The engine!
Have u map ur s on normal gas? In Germany we have 95, 98 and ultimate with 102 octane on the gas station!
Sorry for the wrong chapter!
The engine!
I'm rhd man and I can tell you there are no kits out there that you can simply bolt on to a rhd and have no modification needed. The abs unit requires either shielding or some form of relocation. Not to mention other factors aswell.
Here is my build thread u can see what I had to do to make it work.
https://www.s2ki.com/s2000/topic/969..._fromsearch__1
Hope it helps you out.
I am making roughly 480whp also. My injectors maxed out that's why we stopped at that level of power.
You don't have to modify anything yet. Wait till your manifold cracks though then the modifying begins. Although I hope it doesn't. People keep proving the mase manifolds do.
We are NOW offering the Stage 1 RHD Turbo kit
http://store.kingsperformance.com/pr...kits-stage-1-3
Let me know if you need anything else that i can help you with.
Fernando @ Kings Performance
