Turbo Kit for my RHD
Old Sep 15, 2012 | 04:05 AM
D-Towncustoms's Avatar
Default Turbo Kit for my RHD
First Question i have is where can i find a Turbo Kit for my RHD (please no no Name charger) ?
And wich size of Turbo will be Good for a First 350+ Hp Goal .
later ich will Strocker the Engine and go p to about 450 Hp.
I have 980 injectors here from my Drift Skyline can i use 4 of them in the s or to Big?
Thanks a Lot
Old Sep 15, 2012 | 05:18 AM
sata3000's Avatar
Should post this in the forced induction forums. Full blown makes a rhd manifold. I use 1000cc injectors . you can hit 450whp without a stroker . Im at 475 on stock block. Do some research and be ready to spend around 10,000$ to have a solid setup.
Sent from my Galaxy S II using Tapatalk
Old Sep 15, 2012 | 06:09 PM
Thanks a lot! There are also no kits avible?
I want the Turbo on the exhaust side! Not in front of
The engine!
Have u map ur s on normal gas? In Germany we have 95, 98 and ultimate with 102 octane on the gas station!
Sorry for the wrong chapter!
Old Sep 16, 2012 | 10:34 AM
sata3000's Avatar
Im mapped for 93 Oct. Post in forced induction chapter. More people will help you out
Old Sep 16, 2012 | 08:33 PM
manny-s2000's Avatar
I'm rhd man and I can tell you there are no kits out there that you can simply bolt on to a rhd and have no modification needed. The abs unit requires either shielding or some form of relocation. Not to mention other factors aswell.
Here is my build thread u can see what I had to do to make it work.
https://www.s2ki.com/s2000/topic/969..._fromsearch__1
Hope it helps you out.
I am making roughly 480whp also. My injectors maxed out that's why we stopped at that level of power.
Old Sep 16, 2012 | 10:00 PM
Johnson86's Avatar
I just installed the Mase 5857 turbo on my RHD and didn't have to modify anything.
Only bad point for you is the turbo is located in front of the engine, and I believe you don't like that
Old Sep 16, 2012 | 11:28 PM
You don't have to modify anything yet. Wait till your manifold cracks though then the modifying begins. Although I hope it doesn't. People keep proving the mase manifolds do.
Old Sep 17, 2012 | 02:18 AM
gettin it's Avatar
Where in Germany are you located? Also, look into the kingsperformance kit. THere turbo sits how you want it.
Old Sep 17, 2012 | 09:39 AM
Kings Performance's Avatar
Former Sponsor
We are NOW offering the Stage 1 RHD Turbo kit
http://store.kingsperformance.com/pr...kits-stage-1-3
Let me know if you need anything else that i can help you with.
Fernando @ Kings Performance
Old Sep 17, 2012 | 04:33 PM
Trackforged's Avatar
Former Sponsor
We also have a right hand drive version available. Is there a reason you want a ramhorn style manifold?
Evan
