Turbo Mani back from Jet-Hot
Old May 26, 2007 | 05:34 PM
  #21
Phillie's Avatar
Where was it done and which coating? 1600 / 2300?
Old May 26, 2007 | 08:36 PM
  #22
hot_kenneth_hot's Avatar
I got my entire kit coated from JetHot inside and out... I LOVE the outcome!!!
Old May 27, 2007 | 11:04 AM
  #23
S2Kyle01's Avatar
wouldnt that be bad to do the charge pipes ? .... dont you want less heat going into the motor ?
Old May 27, 2007 | 11:07 AM
  #24
Phillie's Avatar
Why did you have it done in the sterling? Its only good up to 1600 degrees.
Old May 27, 2007 | 06:03 PM
  #25
Raven628's Avatar
Do they do it in Black?
Old May 27, 2007 | 06:51 PM
  #26
S2Kyle01 = All it does to the charge pipes is keep them EVEN cooler than without coating...
Phillie = I got it done in the sterling because I am also going for looks on my car! I think the bright sterling makes the pipes look badass!!!
PLUS, 1600degrees is better than NO coating at all!!!
and i'm not too sure how hot the pipes do actually get, but none of the coating has came off! So it might not even get to that much.
Old May 27, 2007 | 09:01 PM
  #27
SPECIAL-OPS-S2K's Avatar
Turbo manifolds heat to excess of 2000 degrees F and there has been threads before stating that the 1600 degree coating had flaking issues after extended use...
Old May 27, 2007 | 09:47 PM
  #28
I didn't know that. but my coating hasn't given me a problem.
Old May 27, 2007 | 11:21 PM
  #29
smirfs2k05's Avatar
[QUOTE=Spoolin,Mar 13 2007, 07:16 AM] I just got my turbo manifold and turbine housing back from Jet-Hot and it looks pretty good.
This coating is good to 2400
Old May 28, 2007 | 07:36 AM
  #30
Originally Posted by smirfs2k05,May 27 2007, 11:21 PM
How in the hell does coating help spool up.
by keeping the exhaust heat IN the piping as opposed to letting it soak into the engine bay... hotter exhaust has a higher velocity therefore moves away from the turbo faster and in effect make the exhaust more efficient and free flowing...
