turbo manifold?
Old Apr 6, 2011 | 06:42 PM
s2k210's Avatar
Default turbo manifold?
hey guys decided to go turbo ive always been turbo guy lol Here my ????????????
with rev hard cast mani or pfab log style top mount mani do i need to do the oil filter relocation
my setup
stock block
doing head now was going all motor changed mind
new valve seal,apr sutds,oem headgasket,stock valves,supertech dual springs retiners,skunk2 tuner2 cams,polished head and portmatched
either one^^^ those mani
aem ems 1052
gt35r
3"dp
to invidia test pipe n catback
godspeed intercooler setup for now
greedy rs bov
tial gate
competition clutch stage2 and light flywheel
looking to run just 10psi for now hope for 380-400hp we see
car dide 195 bone stock
with invidia exhasut hytech header and the clutch setup on stock ecu 217hp
Old Apr 6, 2011 | 06:46 PM
passmans2kny's Avatar
go tubular mani, if not def do the pfab log
Old Apr 6, 2011 | 07:00 PM
s2k210's Avatar
yes i like the pfab i had it on bseries turbo in my ek nice mani
and i just looked up both neither require oil relocation
with the pfab mani i no i will get more power out the car
Old Apr 6, 2011 | 07:55 PM
DFWs2k's Avatar
with those low power goals, go with gt30 or gtx30
Old Apr 6, 2011 | 08:54 PM
Deception's Avatar
revhard requires oil filter relocation
Old Apr 7, 2011 | 12:38 PM
s2k210's Avatar
^^^thanks bro..
and was thinking of going gt30
Old Apr 7, 2011 | 01:04 PM
Deception's Avatar
^^^thanks bro..
No problem. You should just get the stage 1 Pfab kit & ask for the turbo to be upgraded to what you want.
Old Apr 7, 2011 | 01:20 PM
Corey Maurer's Avatar
Agreed..
Old Apr 7, 2011 | 01:27 PM
riceball777's Avatar
the p fab log does not need an oil filter relocation kit but you may have clearance problems with the fuse box and battery. Most likely you will have to turn the fuse box.
the rev hard log manifold needs an oil filter relocation kit and you must run an E compressor cover on your gt35r. A S cover will hit the frame.
i have the rev hard log. i do not recoment a log manifold for the s2000. It will rob you of a lot of power and force you to set Vtec well above 6k RPM.
Old Apr 7, 2011 | 01:36 PM
i agree, with a tubular manifold you can make the same power at less psi, efficiency wins
